So where have you been mounting the CB's?
Old Jun 12, 2012 | 10:43 AM
  #211
Kreep's Avatar
Originally Posted by Rooster76
I put a 90 degree connector from Radio Shack on the back of my radio for the coax so it wouldn't bend against the window. After it was mounted i realized that I probably didn't need it with the small PL-259 connector of the Firestick Firering coax.
Radio Shack
PL-259 Inline Right-Angle Adapter
Model: 278-199 | Catalog #: 278-199
Handy, but should be considered a last resort. Our club holds an annual CB tuneup. One of the members brings in some really nice gear for testing and tuning your SWR. Removing that little right angle adapter dropped me from over 3 to 1.1
Old Jun 26, 2012 | 09:04 PM
  #212
Sabotage70's Avatar
I mounted mine above the mirror. I have access to a sheet metal and a break so I made my own bracket.
To insure that I had a secure mount needed to screw it to the metal of the windshield frame.
I wish I would've have cut the panel I little straighter. But you can't really see it now that the radio is installed.
This basically what I started with.
And this is what it looks like now that it's installed
Old Jul 12, 2012 | 08:54 PM
  #213
maverick17's Avatar
Subscribing...
Old Jul 15, 2012 | 01:18 AM
  #214
jcalabria's Avatar
Default Cobra 75 in center console
I chose to mount my Cobra 75 in the center console for several reasons. I wanted to be able to get the connection box in case I wanted to run a 3.5mm speaker cable to my radio or to an external speaker later. From what I understand the unit senses the cable and shuts off the internal speaker when a cable in plugged in, so if I mounted it under the console I would not be able to have a coice of using the internal or external speaker. Anyway, I like how the install turned out, let me know what you think.
ID:	341245Click image for larger version
ID:	341246Click image for larger version
Old Jul 15, 2012 | 12:23 PM
  #215
maverick17's Avatar
Attachment 341245Attachment 341246Attachment 341247
I met up with another JK'r local to me who uses the same CB... he mentioned something about piping the external audio through his stereo. I forgot to ask him how he was doing that... the only thing I could figure is he connected the external speaker jack to his Auxiliary input for his stereo... since I'm not sure I could be wrong. But I thought I'd pass that idea on... if you're looking for an external speaker set up.
Old Jul 16, 2012 | 09:33 AM
  #216
jcalabria's Avatar
That is exactly how I plan on doing it and the reason I have to be able to get to the control module is if I want to be able to use either the handset speaker or the Jeep audio. If the unit gets installed behind the dash or under the console you can't change your mind later because you can't unplug the 3.5mm jack from the control module. If my antenna shows up this week I should be able to let everyone know how it works out.
Old Aug 2, 2012 | 07:17 AM
  #217
AlphaRomeo15's Avatar
Just finished mine on my 2011... In the dash, had to fab a mount, the mount it came with wasn't deep enough to touch the bottom of the little cubby.
ID:	348686   Click image for larger version
Old Aug 5, 2012 | 07:09 PM
  #218
The Dark Knight's Avatar
Originally Posted by AgtSunshine
I did this same set up on my 2012 Rubi with a Cobra 29LX and it worked out great this past weekend up on Drummond Island! Thanks for posting the part details!!
I just had to add some velcro to the back half of the radio to keep it against the windshield headliner (prevent the radio from tilting).
Some thoughts post-install:
You'll want the mike cord away from your rearview so attach the mike clip on the right hand side of the radio and just feed the cord over to that side and through a retainer of your chosing.
To do this, it's best to to mount the radio as far to the LEFT as possible..to the point of where it almost touches your driver-side sun visor. This way, you can mount the mike on the right-hand side while leaving enough room for the passenger-side visor to move freely.
Thanks again!
Good tip on actual mount location.
Old Aug 5, 2012 | 07:31 PM
  #219
Jhen's Avatar
I have the Midland 75-822 and attached it to where my dome light used to be.
Name:	IMG_0022 (800x600).jpg
Old Aug 5, 2012 | 07:37 PM
  #220
Lancejk's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=349914"/>
What are those lights?
