Where should i mount my cb in my jk
Old Jul 16, 2012 | 04:24 PM
dhubers's Avatar
Originally Posted by Willis19
What mount did you use
I used the mount that came with the radio. It was tight & put some strong double back tape to help out with the screws.
Old Jul 16, 2012 | 05:07 PM
Sabotage70's Avatar
Originally Posted by Jethro
What are the drawbacks to using the Cobra 75 vs. more traditional CB units? They're all regulated at 4 watts right? I also understand that the antenna makes a lot of difference in clarity and such. I like the idea of using the 75 because I'm not satisfied with any mounting options for a larger unit.
Pros and Cons of the 75 please.
Thanks
If your state has a no cell law like we do in Nevada. Having all the buttons on the mic would make it illegal. The way the law is written cb's are exempt because they only one button on the mic.
Old Jul 17, 2012 | 05:00 PM
dhubers's Avatar
Here is a couple of pics of cb above the mirror it does work with hard top to.
Old Jul 17, 2012 | 05:30 PM
VolsJeep's Avatar
I have a 6 spd 2 door, so I will have to rule out the passenger side of the consule. And the idea of having it above the mirror doesn't appeal to me. Are there any other suggestions as to where a cb can be mounted?
Old Jul 17, 2012 | 05:40 PM
McNultyOttawa's Avatar
You might laugh at me for this but this is where mine is mounted...
I attached two brackets to the bottom of it, and then used that velcro tape on the center console and bottom of the brackets. The console still flips up easily, and it doubles as an arm rest.
It was a temporary spot that I have just never bothered to invest more time into because it really doesn't bother me
Old Jul 17, 2012 | 05:43 PM
sixt7gt350's Avatar
OLD school CB mounted inside center console.
The mounting bracket is one of the metal portions that were cut off when I stubbied my factory front bumper.
Incredibly cheap and easy, some would call it "ghetto," but it works and protects the CB from mud showers.
https://www.jk-forum.com/forums/jk-w...l-cheap-80045/
Old Jul 25, 2012 | 08:16 PM
maverick17's Avatar
My recent CB and antenna install:
ID:	345643Click image for larger version
ID:	345644Click image for larger version
ID:	345645Click image for larger version
Old Jul 26, 2012 | 12:22 AM
Sahara_Maverick's Avatar
When you guys install the radio on top of the rear view mirror do you run the coax through the roll bar or under the carpet all the way to the back?
Any advantages or caveats using either option?
Old Jul 26, 2012 | 03:03 AM
tslewisz's Avatar
I ran it under the roll bar padding from the windshield to behind the front seat and under the carpet from there. Carpet's gone now so it's zip tied with the other wires running back there at the top of the tub, passenger side.
Old Jul 26, 2012 | 05:36 AM
maverick17's Avatar
I ran my coax along the top of the roll bar (under the padding) using something to fish it (a straightened hanger). I ran it all the way to the rear roll bar support and then down. Since I mounted my antenna on the passenger side... there's a rubber grommet near the rear roll cage support where the tail light cabling enters the fender... I created a small hole and ran the coax through that.
I picked up my antenna mount at a local CB supply store... and its designed to be hardwired to the coax. I went with the passenger rear corner at a friend's suggestion but I will say this was very difficult since you have to work through the taillight opening and there's a metal flange that stickes out just before the mount (you'll see it in my second pic).
The alternate location (suggested by the CB store) was to the right of the driver's taillight (between the taillight and gate). There's an indentation or thin section of the body (felt when the taillight is removed) where the mount can be attached... probably easier to wire but you'll do it blind since due to the extreme angle. The antenna will also be in the way of opening the hard top rear glass as the antenna would barely overlap.
ID:	345714 Click image for larger version
Hope this helps.
