Where should i mount my cb in my jk
Old Jul 26, 2012 | 12:55 PM
  #31
Rooster76's Avatar
Originally Posted by Jethro
What are the drawbacks to using the Cobra 75 vs. more traditional CB units? They're all regulated at 4 watts right? I also understand that the antenna makes a lot of difference in clarity and such. I like the idea of using the 75 because I'm not satisfied with any mounting options for a larger unit.
Pros and Cons of the 75 please.
Thanks
The cobra 75 has to have a small box mounted that usually goes under the glove-box. There is a midland 75 that is more portable. I break it down more here LINK->https://www.jk-forum.com/forums/jk-c...7/#post3070835
Originally Posted by VolsJeep
I have a 6 spd 2 door, so I will have to rule out the passenger side of the consule. And the idea of having it above the mirror doesn't appeal to me. Are there any other suggestions as to where a cb can be mounted?
I wasn't super digging the idea before I did mine. The speaker is set up on most CB's on the bottom which is a plus for up there. Also If you drop the mic it is pretty easy to grab. If your worried about the mic cable being in the way you can sort of tuck it up and lock it in place when your not using it.
This isn't my jeep but you can see what I'm talking about
Originally Posted by Sahara_Maverick
When you guys install the radio on top of the rear view mirror do you run the coax through the roll bar or under the carpet all the way to the back?
Any advantages or caveats using either option?
I went up the roll bar. It was much easier then going along the ground.
Originally Posted by maverick17
FYI... I used this set up to do my CB... but I made one modification. I substituted the 3/8" clamps with 1/4" clamps instead. The smaller clamps were able to crip the windshield loop tighter reducing any slack especially when mounting a large radio like the Cobra 148 GTL or 29 LTD Classic. ...
I tried the 1/4" clamps and they didn't work for me though I could see how you could bend them to work. I had a small bit of play in mine (3/8"). I found that if you don't put the L brace sandwich in the clamps then you get a tighter fit. I'm glad you got it to work in the end that's all that matters.
Old Jul 27, 2012 | 02:51 PM
  #32
Sabotage70's Avatar
I like your antenna mount. Nice job.
Old Jul 27, 2012 | 06:34 PM
  #33
maverick17's Avatar
Thanks... I found the key to it is using a magnet to hold the nut while you fish the fingers in to get it started and threaded on. I had one of those tools that extends with the magnet on the end... also helps when you drop something into the fender. Not that I'm speaking from experience or anything. GRIN
Old Jul 30, 2012 | 06:56 AM
  #34
Team Desert Eagle's Avatar
Originally Posted by Sergeant Seda
quadratec.com has what you need i just bought one its great.
I looked for this mount on their site but did not find it. Do you have a part number or a link??
Old Jul 30, 2012 | 09:50 AM
  #35
maverick17's Avatar
Try searching for "CB" on quadratec... it came up with a few CB related items to include a couple of antenna mounts etc...
