~~~Cheap and easy LED Rock Lights!~~~
Old Sep 2, 2009 | 05:41 AM
  #131
whpony96's Avatar
Originally Posted by BonsaiMan
Could these be controlled by a switch and wired to come on when you unlock the jeep. Would help in the parking lot and draw attention if the alarm goes off.
Originally Posted by SFD1248
Did I miss a write up in all the pages of where you ran all the wires and to what switches if you weren't doing the lights on when unlocking? Just curious as to where all you ran them. Can these lights be used on Stock Sahara fenders also?
TIA
Andrew
Ummm yep you missed a lot, time to start reading...LOL
As for the stock Sahara fenders yes you can but you will need to pick up some aluminum stock from Home Depot or Lowes to make some brackets for the LEDS.. or you can do some of locations that others have posted on here. I wanted the LEDS to be as far out to the edge as possible so I could have light out by the sidewall of the tire.
That's exactly how they are wired here. That's what the DIODE is for....
Old Sep 6, 2009 | 07:06 AM
  #132
Lee's Avatar
Lee
whpony96 tHanks for all of the great info. I copied your work and the results are great!
Thanks
Old Sep 6, 2009 | 04:50 PM
  #133
sleeves's Avatar
just did my front footwells today, probably one of the easiest mods i've ever done. going to start on rock lights tmrw.
Old Sep 6, 2009 | 06:19 PM
  #134
whpony96's Avatar
Thanks
Your VERY Welcome! I am just glad I can contribute back to a community that's helped me soooooo much!
PS: Post some pics bud! I wanna see them!
Old Sep 7, 2009 | 02:15 PM
  #135
marsolek84's Avatar
This looks like a great thing to add under the hood. I was looking at my rubicon and I have a "hood pin switch" that is located near the windshield washer fluid tank. This is used for the remote start so you can not remote the vehicle if the hood is open. This switch is a ground switch and the side that you would want would be the purple with bluish grey stripe. This wire is only neg when the hood is open. Wire up your lights to a 12v source and wire the neg side to the purple/blue-grey stripe wire and BING BANG BONG these lights come on only when the hood is open. Switch is a good idea if you dont have the hood pin switch, but you can forget it and leave them on....I have seen these switches everywhere and they are a couple bucks is all(if yours doesnt have one allready). Fully adjustable too so if the hood sits higher even when closed it will still be off. PM me if you need any other help.
Originally Posted by whpony96
These also work great for under the hood work lights!
Old Sep 7, 2009 | 03:07 PM
  #136
bluerubicon08's Avatar
I've been looking for an inexpensive rock light solution that is also waterproof. Thanks! I have LED interior and footwell lighting already installed. These will be a great addition
Old Sep 12, 2009 | 05:27 PM
  #137
sleeves's Avatar
got the front wheel wells done, need more lights.....
Old Nov 3, 2009 | 02:02 PM
  #138
officer_vince's Avatar
Thanks for the link to that website. It is quite awesome. In a matter of minutes I have found hundred of dollars worth of LED's that I do not "need" but want to put on my Jeep so bad!
I think I may tackle the rock-light mod when spring gets here.
Old Nov 3, 2009 | 03:39 PM
  #139
whpony96's Avatar
Oh tacle it now or you won't get to see how cool they will look with snow on the ground!!!
Old Nov 8, 2009 | 09:01 PM
  #140
jeeptheone's Avatar
Just ordered some to be sent to Australia. Cant wait to get these on as it will make the night runs so much better.
Thanks mate for the post up on these lights.
JTO
