Cabin Air Temperature Sensor Location?
Old Jun 12, 2012 | 04:13 PM
mattro's Avatar
Default Cabin Air Temperature Sensor Location?
Does anyone know where the following sensor is located? I have the sensor just have no clue as to where to install it.
SENSOR. Temperature Cabin Air.
Stock Code 55111178AC
Description: SENSOR. Temperature Cabin Air. . "Instrument Panel Parts Module"+"Air Conditioning w/Auto Temp Control". Required: 001
I upgraded my AC/Heat control module to an Automatic Temperature control unit, and I believe this sensor will make it work better. It is working OK now, but could work better in certain situations.
Old Jun 12, 2012 | 05:57 PM
Gossamer's Avatar
Bump, curious on the answer as well!
Old Jun 12, 2012 | 07:18 PM
moto-scoot's Avatar
ID:	328747Click image for larger version
Name:	sensor in car atc.jpg
here it is. got some major issues with wiring if jeep wasnt built with this
located on right side just below sterring column
you will also need the vent holes in plastic cover below steering column
Old Jun 12, 2012 | 07:27 PM
mattro's Avatar
Great info. Thanks. Any ideas of what it wires into? I suspect I'll find a wiring harness behind the cover.
Originally Posted by moto-scoot
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=328747"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=328748"/>
Old Jun 12, 2012 | 07:46 PM
moto-scoot's Avatar
it wires to the atc head.
ties in to the evaporator sensor also.
dont know if wiring is there on all jeeps.
cant see your atc working corectly without this sensor....Good Luck
Old Jun 13, 2012 | 05:10 AM
Gossamer's Avatar
Sweet! Keep us posted on success. I am def interested how it all works out with wiring.
Rick
Old Jun 13, 2012 | 09:28 AM
StuFarmer's Avatar
Yes, I'm very interested in all that is applicable for this Auto A/C installation. I've already ordered the Master A/C Module per the comments made here, but have yet to pick it from the dealer. If this becomes much more involved I believe I'm out.
Old Jun 13, 2012 | 01:10 PM
Gossamer's Avatar
I popped off that panel in hopes of seeing a wiring harness dongle there but didn't see one. That sensor that you ordered, does it have any wiring on it or is it just a sensor that screws in right behind the slotted part of that panel?
Rick.
Old Jun 13, 2012 | 01:17 PM
Gossamer's Avatar
Attachment 328747Attachment 328748
Any other information where this came from, definitely helpful, curious on the wiring harnesses needed.
Old Jun 13, 2012 | 07:28 PM
mattro's Avatar
The sensor has a spot on the back that a harness plugs into. I'll take some pics tomorrow.
Rick.
