Fog Lamps on with High Beams?
Ok...that makes a little more sense. I would still be prepared to reap what you sow with a possible ticket. At least with them being on only with the high beams there'll be less of a chance.
As for having fogs on with high beams, I agree it would be a great combination, however there is a reason it is illegal in most states that won't let you marry your sister.
Approaching a vehicle that has both high beams and fogs is much worse than approaching a vehicle whith just the high beams on. When the asshole keeps his high beams on you can at least look to the side a bit, and still see the road. But since fogs are designed to scatter the light directly in front of the vehicle, it makes it much worse the closer you get to the vehicle.
Illegal lighting is a pet peeve of mine. My wife was blinded by some asshole with a bunch of aux lighting one night and ran off the road into a ditch. Our grand daughter was also in the vehicle. I thank God for watching over them, as they were just bruised and shaken up a bit.
Now any time I see a vehicle with blinding lights approaching, it takes all I have to not go into total road rage.
Having a dual setup could be good, as you described. I think the way to do it would be to run a new power wire from battery to relay, to lights. Then take the stock power wire and also run it to the same relay. This way if the relaly gets hot from the OEM switch, it goes on. Or, if it gets hot from your newly wired switch, it goes on.
Ok. You're right. No one ever did say that. They also never said they wouldn't be. So, how was I supposed to know? All I was trying to do was get more info on what you were trying to accomplish. I can take a hint. When I see crap like this, "however there is a reason it is illegal in most states that won't let you marry your sister.", I don't need to try to help anymore.
LOL. I didn't say that! It's all good. I don't think anyone, well, not me or the OP'er at least, was trying to offend. Just gather data. I always figure the people on here who are trying to modify their Jeeps for the better, know enough to not drive with high beams on in fog. Those laws and the overrides in controls that the manufacturers design, are for the other 99% of the morons out there. "DUH, I CAN'T SEE IN THIS FOG. I BETTER ADD MORE LIGHT TO THE SITUATION! THERE, HIGH BEAMS ON IN SNOW STORM. NOW I CAN REALLY SEE THE SNOW FLAKES BETTER!"
That being said, I'm about to attempt to drive to work without doors or freedom panels for the first time tomorrow since it will warm up to... 40! sO MAYBE WE'RE NOT SO SMART AFTERALL. dont' know when to come in out of the rain either.
