Custom modular JK hardtop
Old May 6, 2017 | 06:38 AM
  #1551
jscherb's Avatar
Something I'm thinking of implementing for the fridge - a fold-up table attached to the side of the slide mechanism. It would work something like this animation shows:
Old May 7, 2017 | 11:02 AM
  #1552
Four Low's Avatar
Totally Cool, the Slide out could hold tool locker, table serve as workbench, any number of uses. Great for Tailgating, Camping, Everything
Old May 13, 2017 | 04:40 AM
  #1553
jscherb's Avatar
Update on the Freedom Panel skylight project... a company has told me they want to go ahead with them. I should be getting preproduction hinges from the hardware company early next week - that's the last piece needed before the kit can go into production. Just have to test those and then everything is sourced - tempered glass panels, hinges, latches, weatherseal, hardware.
Old May 13, 2017 | 10:08 AM
  #1554
jscherb's Avatar
The MORryde slide arrived a few days ago. I haven't had time to install it yet, but I did a quick test when it arrived to see how it might work out. Since it's not bolted in yet I'm supporting it with a 2x4 for the photo.
It's a double-extension slide, and in the photo above I have the fridge sitting on the furthest extension, but I'm thinking a better way to do it might be to mount the fridge on the first extension and then have the second extension pull out beyond the fridge. The second extension would have a drawer and the tabletop. Something like this:
In this next photo I've set a swivel/slide on top of main slide, it could be used to turn the fridge 90 degrees once the main slide is pulled out, and it could also move the fridge to the side a bit on its own short slide.
Haven't decided what I'll do yet, I'm still working on design ideas.
Old May 13, 2017 | 10:15 AM
  #1555
Four Low's Avatar
Instant Picnic Table, Workbench, so many possibilities ! Will be looking forward to seeing this "available" soon
Old May 14, 2017 | 04:14 AM
  #1556
kklasman's Avatar
It's very common in the overlanding world to put a stove in the second extension.
Old May 14, 2017 | 06:29 AM
  #1557
jscherb's Avatar
I've got several ideas for accommodating both a stove and a work surface, stay tuned. I'll do some concept drawings for everyone to comment on.
Old May 14, 2017 | 02:45 PM
  #1558
jscherb's Avatar
I'm working on two design ideas for a slide-deployable kitchen.
This first idea has a two-part folding table. The table folds vertically against the fridge; when it's folded down the second section flips forward to provide a fairly large table. This concept drawing shows the sequence of stowing the kitchen:
The table would be large enough to provide for a small stove plus a work surface, as well as providing full use of the drawer that slides out from under the fridge.
In this next idea, the fridge is mounted on a swivel, and swivels to the side. The drawer can slide closed under the table so it doesn't get in the way when you're working at the table. This shows the sequence of deployment:
There would be room for a stove with this option as well.
Old May 14, 2017 | 03:48 PM
  #1559
Four Low's Avatar
Nice ! The drop- down lid on your StoreGate adds another work surface ; 21st Century Chuck Wagon !
Old May 15, 2017 | 03:10 AM
  #1560
kklasman's Avatar
In several of the designs, the table when folded up seems to block what looks like a vent in the lower front corner of the fridge. Could that be a problem while running the fridge while its stowed away?
