Old Jul 22, 2012 | 09:10 AM
  #1111
Dps50's Avatar
As far as I know, the dual battery won't work on 2012. But that may have changed. I thought about dual battery, I had 3 on my excursion. Just didn't feel like messing with the isolator and all that this time around. I will probably try the sears deep cycle when the time comes. My fridge doesn't draw that much, about 1.5A/hr avg. Trying to keep this a minimalist build. And I opted not to get the 18" extension, if I need to cross something that requires that much height, I will find another way around or rent a boat. Plus the extension looks a little ghetto/afterthought.
Here are some pics.
ID:	343982ddClick image for larger version
ID:	343983Click image for larger version
ID:	343984Click image for larger version
ID:	343985Click image for larger version
Originally Posted by Bingo
Nice snorkel i like it a lot
I was loocking for that snorkel long time a go
I Have congo cage and i would like to know if i can fit that snorkel with with the rack on
is it possible to you to give us more picture : 1 from the driver side (close )
1 from the inside on Passenger side for my wife
and did you buy the 18'' extension ?
Thank's
Pat
Old Jul 23, 2012 | 02:03 AM
  #1112
Mark Doiron's Avatar
Originally Posted by kleinrider
I'll post mine for you, as it's basically the same one. The only difference, I believe, is that I got the stubby bumper, and Mark's is the full width one (plus I had them cut a hole for my trailer harness (near the left side reverse lamp) and an antenna mount on the driver's side.
Thanks, Kleinrider! Sorry for not responding to posts with questions directed at me, but I've been traveling. Pic's of El Malpais (Grants, NM), Toroweap (Grand Canyon), Mt Lemmon (Tucson), Soldier's Pass (Sedona) to come soon!
Old Jul 23, 2012 | 02:09 AM
  #1113
Originally Posted by SBEII
How do you run the wires to the lights on your roof racks?
Right now, since my lights are set back from the windshield, I have a harness that I stow in the opening in the engine compartment behind the batteries. When off road, I pull out that harness and run it up to the lights and connect it up. It ain't pretty, but it gets the job done. As suggested, once I get the light repositioned over the windshield, I will run it up the tube for the rack (it will require custom welding to mate the MBRP rack extension to the AEV snorkel).
Old Jul 23, 2012 | 02:11 AM
  #1114
I appreciate it. What type of lights work best up there as an all around use light; fog, driving, long range? I was thinking of getting the long range bu I'm still undecided.
I went with the long range up there. When I put my fogs, low beams, and bumper mounted KC driving lights on, I have a very nice, well-lit pattern in front of the Jeep. I was also concerned that since these lights are set back a few feet from the windshield (temporarily so), that I'd lose light into the roof panels. So, I wanted more sight distance down the road. This provides it. I've debated replacing a couple of the KC Slimlites with some of the larger lights that are common on expedition rigs--more for aesthetic reasons than anything else. Would appreciate anyone's thoughts on that, as well as recommended lights.
Old Jul 23, 2012 | 02:19 AM
  #1115
Originally Posted by Dps50
As far as I know, the dual battery won't work on 2012. ...
There is a kit that will fit the '12s. It stacks the batteries on top of each other. I won't tell you the vendor because I had my share of headaches with them, they used to be a sponsor here, and to be honest I don't even know if they're on the banned list now. But, at least you know it's feasible.
Old Jul 23, 2012 | 04:44 AM
  #1116
kleinrider's Avatar
No problem; I figured you were out on another trip!
Old Jul 23, 2012 | 05:36 AM
  #1117
TejasRubi's Avatar
I guess my 2007 was more of an expedition build as that's mostly what I used it for.
Here's a pic from Port Orford, OR on our way back to Texas from the 2010 Winter Olympics in Vancouver, BC.
How she sat when I was done.
Now she will be replaced by this 2012 I picked up this past weekend. I can't wait for the build process to begin.
Old Jul 23, 2012 | 05:48 AM
  #1118
nitecrawler's Avatar
Just finished doing my fender trim, license plate relocate, and homemade Jerry can mounts
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
ID:	344322   Click image for larger version
Old Jul 23, 2012 | 08:12 AM
  #1119
bigmike17's Avatar
How'd you make the Jerry Can mounts?
Old Jul 23, 2012 | 01:20 PM
  #1120
KhakiStinger's Avatar
Ordering my Artec axle truss for front axle tonight.
