Old Jun 22, 2013 | 06:26 PM
  #2741
Cochise12's Avatar
This is a great thread! Just out of curiosity...how many of you with the exp. modded jeeps actually disconnect your sway bars? I know that the rock crawlers disconnect them all the time, but what about when you're just cruising through the back country? I've discovered the joys of airing down on washboard roads, but am wondering if I'm missing something by not disconnecting. I'm not going to be a rock crawler...my jk is my daily driver plus I like keeping my cars/jeeps in good condition. I mainly use it to explore the owyhee and sawtooth mountains here in idaho. Btw, I own a sport so I'd have to buy manual disconnects which I hear can be a pain in the buttocks.
Old Jun 22, 2013 | 06:36 PM
  #2742
NTXRUBICON's Avatar
I have a rubicon and I disconnect all the time I also have manual disconnects due to the Rubi electric disconnects not always being the most reliable on the market.
Old Jun 22, 2013 | 06:37 PM
  #2743
NTXRUBICON's Avatar
Also I daily drive mine as well
Old Jun 22, 2013 | 06:40 PM
  #2744
ScubaDude's Avatar
Look for the thread "home mod sway bar disconnect" real cheap discos that work.
Old Jun 22, 2013 | 06:43 PM
  #2745
Cochise12's Avatar
Thanks for the info. I'm mainly wondering if its worth it. How often do you use yours?
Old Jun 22, 2013 | 06:44 PM
  #2746
k0260's Avatar
using your discos on rough washboard dirt roads will also help smooth out the ride, especially at speed, allows the axle to 'float' freely under the jeep. If I am driving any rough dirt roads, I disconnect for the smoother ride. Manual disco's are quick and painless once you've used them a couple times. Depending on what brand/type you go with of course
Old Jun 22, 2013 | 06:52 PM
  #2747
Cochise12's Avatar
Thanks! I think you guys have "swayed" me....sorry for the pun, I couldn't resist. I'll check out the cheap disco thread and see what's available. Does anybody have recs re companies they like...or don't like?
Old Jun 22, 2013 | 07:00 PM
  #2748
ScubaDude's Avatar
You shouldn't drive much faster then 25 mph with your sway bar disconnected though right?
Old Jun 22, 2013 | 07:02 PM
  #2749
Cochise12's Avatar
That's what I've heard too. Probably impacts cornering at high speeds pretty badly.
  #2750
NTXRUBICON's Avatar
I have but not recommended I try to.keep it under 20 when I'm disconnected
