Old Jan 16, 2014 | 12:16 PM
  #3341
Mark Doiron's Avatar
Originally Posted by Gforce!
Mark, have you ever considered doing a diesel swap? I've put some thought to it as a "once i get the time and money" kind of project, mostly because of mileage.
No, I haven't. I can live with the gasoline motor here in the U.S. But, maybe the next Jeep ...
Old Jan 17, 2014 | 09:29 PM
  #3342
NMBruce's Avatar
Lets talk tire repair kits, what do you carry?
Found these 2
Viking Tire Repair Kit
https://www.extremeoutback.com/produ...epair+Kit.html
here you can buy more patches & plugs
Tire Plug Kits :: Kartek Off Road Parts & Accessories
Old Jan 17, 2014 | 10:52 PM
  #3343
wmphoto's Avatar
Originally Posted by Krizzy1107
Can we get a pic of what the camera looks like and what monitor are u using
here is the best pic of the camera... as for the monitor... it is the stock head unit. RHR I think... It's the stock nav unit with a lock pic installed.
Old Jan 18, 2014 | 10:06 AM
  #3344
toxicity_27's Avatar
So I'm going to be turning my JKU into an expedition/overland rig and I'm going to change out my lift. It is my DD and I am looking at AEV kits. I like the look of my 4" but it seems a majority of people here run a 2.5", would running the 3.5" from AEV be a huge negative for me? Any other recommendations?
Old Jan 18, 2014 | 01:52 PM
  #3345
LoneWolf's Avatar
I look forward to seeing people's opinions on this as well. I plan on a hybrid expedition build for my two-door, but I've been torn between the 2.5 and 3.5 in part for this very reason.
Old Jan 18, 2014 | 03:30 PM
  #3346
NMBruce's Avatar
my $0.02 from what I have learned on here and what I think. can you get by with the 2.5" lift, will it clear the tires you want? the lower lift should help in wear and tear on the drive train & suspension and could give a little better return in MPG. I put on a 2.5 MetalCloak and skid plates to protect the underside of my Jeep.
If you haven't already, You might like reading page 162, post 3234
Also found this
http://www.expeditionportal.com/reso...d-vehicle.html
Old Jan 18, 2014 | 03:42 PM
  #3347
Dlampe's Avatar
I wouldn't change out a 4 for a 2.5 or 3.5. I have a 3.5 with another 3/4 spacer but with the full width arb bumpers, full roof rack, tire carrier and all the gear that goes with it the jeep settles quite a bit. Fully loaded it needs all the lift I have to clear the 35's. Now, you could run smaller tires and a lot of people do. I personally like the looks of a 35 inch tire on a 4dr. On the 2012 and newer, if you run a 2.5 inch lift, you will need a front shaft and exhaust spacers anyway.
Old Jan 18, 2014 | 03:56 PM
  #3348
SKTN Rubi's Avatar
^ nice jeep. I agree with the factoring in the weight of bumpers, and the latter 35" tire size that will be going on after the lift sooner or later.
I think I will be going the 3.5" rather than 2.5" when I do now. Thanks.
Sent from my recliner
Old Jan 18, 2014 | 04:03 PM
  #3349
Scootersjk's Avatar
Here is my 2 door with AEV 2.5 and 33 Duratracs
Old Jan 18, 2014 | 04:05 PM
  #3350
Also found this
The 10 Commandments of Modifying an Overland Vehicle - Resources - ExPo: Adventure and Overland Travel Enthusiasts
I've read that link, and that post, while it helps a little, it doesn't quite answer my question. Thanks for the reply.
One of my biggest reasons for wanting to switch is the ride quality on this lift. With it being my DD it is an incredibly rough ride. I want something that handles a little bit better and has a little smoother ride. Before you flame me and say it's a Jeep yada yada yada. I get that, I don't mind a rough ride, I actually prefer a rough ride over a smooth ride. This ride is just that much worse. I can't hit a bump in the road without being bounced around all over, and hearing my things in the back bounce around.
I think that's the route I'm going to be taking as well. It was another thought of mine to go with the 3.5" because of all the added weight.
