Old Mar 6, 2014 | 09:50 AM
  #3571
Warrenhdavis's Avatar
Default 2013 JK Unlimited setup for Overlanding
I went with a 1.75" leveling kit on the front, no spacers on the back springs. Decided to "lift" the fenders instead. The tires are 315x70x17 on 4.5 backspace rims, 3.73 gears. I also added a Swaybar quick disconnect in the frot and Sumosprings in the back to help bottoming out. Added the Superchip programmer setup for 91 fuel tune and get 14.5 around town and 19~20 on the road.
My only problem now is I am still trimming the rear inner fender area to help with a minor rub on the front of the rear tire. The 2013 JK's already have the lover pinch seam trimmed from the factory.
ID:	535549   Click image for larger version
ID:	535550   Click image for larger version
ID:	535551   Click image for larger version
ID:	535554   Click image for larger version
Old Mar 7, 2014 | 07:09 AM
  #3572
Septu's Avatar
Bruce, are you not worried about smashing the air tank? Any plans to put a skid of some sort over it?
Old Mar 7, 2014 | 12:56 PM
  #3573
NMBruce's Avatar
I had thought about that, the tank seems thick, but I think a small skid plate would be good
Old Mar 7, 2014 | 01:46 PM
  #3574
olyelr's Avatar
You didn't add any bump stops? You need extended bump stops for 35's, lifted or not. That, or A LOT of trimming.
Rig looks good!
Old Mar 9, 2014 | 01:53 AM
  #3575
Mark Doiron's Avatar
Originally Posted by Cool Danish
Very nice!.. Looking forward to the rest of the install..
Does the Nutserts require a special tool to install? Where do you buy these?
Yes. A friend of mine had everything I needed.
Old Mar 9, 2014 | 03:01 AM
  #3576
Originally Posted by Tankerbell
Is it pretty easy to fully remove the drawer/tracks for times when you don't need it? Really like the setup for Expedition use but seems to cut down on storage for daily driving use (off it's not removable)
I'd estimate 15-20 minutes to remove. Easier with two people.
1. Remove four bolts, nuts, washers that hold cargo rack. Remove rack.
2. Slide out, unbuckle and remove fridge.
3. Remove four bolts that hold fridge slide. Remove slide.
4. Remove five bolts that hold mounting plate to Jeep floor. Remove plate and drawer as one assembly.
Having used this for the past several days in the Gila National Forest, let me say how much I like it. Access to gear is way easier than before. Really worth the expense.
Old Mar 9, 2014 | 07:22 AM
  #3577
Dlampe's Avatar
about this time of year I start looking for things to change, in most cases just because I'm tired of the way they are and just want to try a new setup. So, right now I have a roof rack that I'm thinking about taking off.
I usually have my trailer and I really don't put that much stuff on the roof. I think I can get by with a trail rack on my tire carrier. Would some of you with this type of rack post a few pictures? I was wondering if there are any draw backs to the trail rack concept vs. the roof rack? Have you ever seen one with the tire off center with jerry cans mounted on just one side?
Old Mar 10, 2014 | 08:39 AM
  #3578
skibovr6's Avatar
It was a cold wet weekend here in Oregon last weekend. Decided to do some camping...in the garage and had a blast. Expedition garage style lol!
Old Mar 10, 2014 | 02:57 PM
  #3579
greggnj's Avatar
That's a heck of a garage^^^^!
Wish I had one..
Old Mar 10, 2014 | 03:22 PM
  #3580
skibovr6's Avatar
Thanks man! The garage has been a work in progress
