Old Jan 25, 2016 | 08:42 AM
  #5591
Jzsquared's Avatar
The nice thing about that side jerry can mount is it moves weight forward as opposed to my cans over rear bumper. Is there one for both sides? As for hitting it, sure. I've ripped off fenders twice, once doing several thousand dollars of sheetmetal damage, hitting things. Maybe I'm not the best example, LOL.
Yes they sell the units for both sides. I think I may get these also they are pretty cheep in the big picture and I think it may add a custom look.
Old Jan 25, 2016 | 12:47 PM
  #5592
Mark Doiron's Avatar
The last day of my recent trip to Anza Borrego and surrounding areas is now online. Los Coyotes Indian Reservation. Enjoy!
https://www.youtube.com/watch?v=YAcndcW6p7c
Old Jan 25, 2016 | 01:59 PM
  #5593
KiwiDave's Avatar
Great video and commentary Mark! You all took some fantastic pictures out there. I noticed that one of the jeeps had a similar hood set-up (axe/shovel). How has that set-up worked out for you?
Cheers!
Dave
Old Jan 25, 2016 | 02:26 PM
  #5594
Cheers!
Dave
I like it. I keep saying I'm going to cut/replace the bolts that hold the axle and shovel on and cause it to be a little longer to get a tool off, but otherwise it's great.
Old Jan 25, 2016 | 02:54 PM
  #5595
Rubicon91's Avatar
Veteran: Marine Corp
Originally Posted by Jzsquared
Thanks for the response , from the sound of things I think I will make my setup to handle 2- 3gallon rotopax. Since 99% of driving is local and this is a vacation rig I think that should be plenty.
I was also wondering everyone's thoughts on the JK Side Mount (Driver Side Universal Tray Kit) - MORryde Products
Not in the means of quality because I have read it's a nice unit, but on its location. I would think that if I ever got into a really narrow situation I could just take it off then reinstall after the obstacle. I am guessing now since I'm new to this stuff but isn't it mounted high enough that it would be really hard for something to hit it here?
A buddy of mine is who actually designed that tray kit. When he was down here a month or so ago he brought the prototype with him so I could see it. Looked really nice and very simplistic to install and remove so I think if you got into a situation where you had to remove it that wouldn't be too difficult at all. It also can mount rotopax instead if you didn't want the jerry can option sticking out. And yes Mark they sell it for both sides. I believe also there is a spot to mount a cb antennae as well on the inside of it so it is up front on the drivers side as well from what I remember him telling me. I am planning to get the drivers side I think for it to mount as Mark said takes weight off the rear and with everything else back there I like the option of moving that weight forward.
Old Jan 25, 2016 | 08:07 PM
  #5596
NMBruce's Avatar
So I have already gotten a lot of good advise on this thread so I'll try one more. I wanted to know those of you that actually get to use your rigs for USA bound overland trips how much extra fuel have you ever needed. Not necessarily how much you bring but what you have actually needed. I run a Genright tire carrier so it has no designated fuel carrier mount but I'm going to add one or two for rotopax.
I really like the side mount Jerry can setups but am afraid that it's in to vulnerable of a spot in case I rubbed a tree or rock or a Sasquatch.
Used my 10 gals going up to Eagle AK, the station in town was closed
Old Jan 26, 2016 | 12:43 AM
  #5597
Having a little fun here with the footage I shot at ABDSP our last night while seated around a campfire. What does everyone think, yeah or nay? These are really easy for me to make, but should I make any more? Interested in everyone's opinions.
Just a lark here to see how it's received. Come join us for about ten minutes of our fireside chat the last night of the Anza Borrego trip. All you'll see is the fire, but you'll hear our discussions of the Carrizo Mountain teeter-totter, two door versus four door Jeep, disconnecting the front swaybar, Painted Gorge run, Los Coyotes run, the best map at the visitor center of the area, fire lookout towers, the wildlife we saw (or in my case did not!), the visitor center films, and water in the Borrego Springs area.
https://www.youtube.com/watch?v=rImXu4LTSck
Old Jan 26, 2016 | 01:11 PM
  #5598
jeepmojo's Avatar
Default all the videos u do are good and worth checking out
As far as the tool holder im thinking a simple piece of galvinised super strut slotted the whole length so threaded rod can be put anywhere . would be almost the exact same thing, just cut to length thats what supports my rear upper rack and 10 feet only cost under $ 20.00 and a couple of minerllac clips to hold the handles for do it your selfers ( electrical supply house has all that ) or home depot more than likely
i noted no one had a high lift jack on their jeep do you all carry them inside ?
i just carry a bottle style jack right now . Do you guys find the use for the high lift jacks in reality ? I understand
its design and functions in some situations however i dont see a lot of people using them other than ornaments usually.
If i added a high lift one not sure if ill put it on passengers side or rear above tire i was thinking it might balance weight distribution on passengers side up front seeing i went with the side
mount jerry can up front on drivers
( personally , i dont want any thing on my hood )
This guy has a cool concept and u could attach stuff to the high lift holes too if needed
kinda cool . https://www.youtube.com/watch?v=CxtNUwlyGXQ
ID:	635756   Click image for larger version
ID:	635757   Click image for larger version
ID:	635761   Click image for larger version
Old Jan 26, 2016 | 01:14 PM
  #5599
Its-a-JK's Avatar
Having a little fun here with the footage I shot at ABDSP our last night while seated around a campfire. What does everyone think, yeah or nay? These are really easy for me to make, but should I make any more? Interested in everyone's opinions. YouTube Link: https://www.youtube.com/watch?v=rImXu4LTSck
Since joining this forum which is pretty recent I have really been enjoying your videos, especially when I watch them on my 60" hd at home and they are inspiring and really really make me want to get out an about. Your commentary helps setup the scene and puts more of a story to the video keeping folks or at least me that much more interested. In fact, I sat a few times watching your videos for 45-60 min at a time.
With that said, even though the fireside chats give more insight into the days events, thought processes and a behind the scenes touch, to me in full disclosure just doesn't live up to your other masterpiece efforts. Maybe you can work it into your main videos in some way but stand alone..........not so much but That just means your main work is that good.
Would love to have the time and money to get out and see the country the way you do, keep those fantastic videos coming👍
Old Jan 26, 2016 | 02:30 PM
  #5600
spicoli's Avatar
Money only does you good if you spend it.
I work full time, not single, etc. I don't often to get the time to do the week long trips that Mark does, but once to 3 times a year I make the time. Usually I just do a weekend trip or a long weekend (3-4days) to get out there and enjoy the world and use my toys.
Sacrifices are made to do these, in my opinion things to do to get out there:
-I have to work longer hours leading up to my trips to make sure I'm not the one holding up the project(s)... And I personally work a lot as it is. My normal week is 50hrs @ work.
-You have to have the gear (tents, camping equip, etc) to make sure you don't spend tons of money. Hotels and eating out a lot cost money. Camping is cheap, but requires prep work. My wife and I have a dehydrator and make great dehydrated meals and/or plan meals so things don't go bad. Gear can be expensive, but once you have a good cooler/fridge, tent, sleeping bag, sleeping pad, cooking gear and luxuries like camp chairs and table to cook you will have them for a very long time if you look after them. All that stuff above can be had for around $500 for decent quality (if you have none of it), get you by stuff for multiple years. You don't need a Yeti cooler or ARB fridge. Get a coleman cooler with a decent lid that snaps shut and you will be fine for a few days ($50-$100). To afford this stuff don't eat out as much, or other such expenditures. One trip eating out and hoteling the whole time will cost $500... if you bought all this gear you would spend another $100 on camp sites, ice and camp fuel (assuming you are paying for camp sites) and the next trip you won't have to spend the $500.
-You have to really want it. You must really want to get out there and enjoy nature to make the sacrifices. I think a lot of people like the idea of it, but when it comes down to it, they like having the comfy bed and conveniences that the home offers. Personally I like the idea that in my jeep (or backpack when I go backpacking) I have everything I need to live for a week, except maybe gas.
-You have to plan leading up to a trip, even if you're not the one planning the trip. A lot of my friends and coworkers that don't get out there much go home at night and watch tv and lounge... I do that sometimes, but time doesn't allow for it when you're leading up to a trip.
I'm not saying you don't do this stuff or don't know this stuff... but when I see people say they "wish they could get out there" I feel like they can, but it is either not their real priority or they think they NEED stuff they actually don't. Sorry to be so winded, but I really like to try to help people realize they can get out there if they want to.
