Old Mar 3, 2014 | 11:59 AM
  #38081
Jeepstin12's Avatar
Making a custom license plate bracket to mount up on the spare wheel. Provisions to add a back up camera. I'll do a little write up when it's done.
ID:	534881   Click image for larger version
Old Mar 3, 2014 | 01:03 PM
  #38082
PFTWHFTB's Avatar
Front and rear rotors and pads, Bilstein 5100's and a teraflex sway bar disco. All put on. Not great pics and will get a flex pic eventually. I have to check my front brake line length to make sure it will make it.
Old Mar 3, 2014 | 01:37 PM
  #38083
JAM85's Avatar
Originally Posted by StevesJK
It wasn't to bad, took a little longer than I had hoped. I removed the hood and had to work on the floor, no real workspace at my house. Using the angle grinder to cut the holes in the hood was the most stressful for me. Never used one before, and it was really easy to cut through the hood and bracing underneath. Also when you are doing the final installation don't tighten the bolts to tight, really easy to deform the hood and make it look wavy.
I have read of guys installing this in 3 to 6 hours, I could see that if you had experience with the angle grinder and had a proper work bench to work on. Mine took so long, my wife had to drive the Jeep to the store with no hood. She was not happy.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=534651"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=534652"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=534653"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=534654"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=534655"/>
I went a week without a hood. Your tips are good info that I also would remind others when doing the install.
Old Mar 3, 2014 | 03:41 PM
  #38084
PFTWHFTB's Avatar
Went and did just a little flex with new shocks and sway discos to see if all worked ok. Not a lot of flex but it's all working
Old Mar 3, 2014 | 06:58 PM
  #38085
LoneWolf's Avatar
Got around to rotating the tires and changing the oil.
Old Mar 3, 2014 | 07:03 PM
  #38086
The Green Monster's Avatar
I ordered 35" Treadwright tires, installed a Tuffy hood lock, installed a Smittybilt oversized tire carrier, and tinkered with my new FlashCal. I should be getting the tires this week and having them mounted over the weekend.
Old Mar 3, 2014 | 10:18 PM
  #38087
jjl509@yahoo.com's Avatar
YES!! Did my front bumper today it was a b$&!% to line up the bolts when sliding the new bumper on but looks sweet all that's left is installing the light bat where u see the logo
Old Mar 3, 2014 | 11:14 PM
  #38088
firefighter53111's Avatar
Originally Posted by jjl509@yahoo.com
YES!! Did my front bumper today it was a b$&!% to line up the bolts when sliding the new bumper on but looks sweet all that's left is installing the light bat where u see the logo <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=534998"/> Sent from my iPhone using JK-Forum
Looks good. I'd buy it if it had fog holes.
Old Mar 4, 2014 | 01:41 AM
  #38089
UKCRD's Avatar
Nice. I'm hoping my reversing camera will land today, too and will be mounting it in the same place, right by the hook!! The monitor is a tricky one to mount as I have too many gadgets and real estate in cab is at a premium! I plan to shift my CB over to the left a tad to accommodate it, which is mounted above the review mirror. Seems to make sense to have the mirror and camera monitor side by side, if possible. Have also got a Rigid Industries Dually arriving today which will be a rear work and reversing light to compliment the two KC reversing lights I already have mounted by the license plate. The Dually is going just above the spare wheel and should fill the light gap nicely. The Delta Light Bar should arrive tomorrow, too and a few other small bits. Should be a good week!!
Old Mar 4, 2014 | 11:09 AM
  #38090
JKMoses's Avatar
290,018 kilometers or 180,247 miles in my Rubicon 2008 Click image for larger version
