Old Feb 28, 2009 | 12:02 PM
  #4511
edwin907's Avatar
Finished my 3rd brake light mod.
1 watt Luxeon red LED with the Tractor Supply reflector and lens from their $3.98 light.
Old Feb 28, 2009 | 12:16 PM
  #4512
KrasnayaZnamya's Avatar
Received my "Special Offer" kit from Turtle Wax with the clay bar, Ice polish, couple bottles of detailer and all the applicators/microfiber cloths...soooo....went ahead and did the full treatment on my JK..
WOW, what a difference!! Now, it may be that I'm still a noob when it comes to good polishes, etc, but man, this stuff rocks!! The ease at which it went on, the fact that I don't have to be careful around the black plastic bits, and the pure shine at the end was an eye opener for me.
Then, of course, the wife's Sahara looked rather depressed next to my X, so I graciously did the same to her Jeep as well...was initially concerned that the darker Red Rock would be more of a challenge to get the same results, but it turned out not to be the case at all.
Both Jeeps look as they they just came off the showroom...I'm sold!!
Old Feb 28, 2009 | 12:26 PM
  #4513
riverzendz's Avatar
Replaced the Fabtech 3" with Pro-Comp 4" coils and Teraflex 9550 shocks front and rear. Got rid of the spacers and gained an inch front and rear.
Old Feb 28, 2009 | 12:32 PM
  #4514
bOLsAK=3's Avatar
Where's the write-up for this mod???
This one's a keeper! Great job!
Old Feb 28, 2009 | 01:36 PM
  #4515
edwin907's Avatar
Here's a quick write up.
Get the LED Module (I got the red one, white might be even better) with Aluminum Housing Low Profile Wide Angle 009 (1W)
from plasmaled.com.
Use the two holes to bolt it to the center cap.
Swing buy Tractor Supply to get the $6.98 (it was on sale for $3.98) Blazer LED Multi Reflective Red 2 in trailer light.
Gut the plastic back of the LED housing to get the reflector and lens separate from the pitifully weak LED.
I used a dremmel with a drill bit (I know, but it was laying on the workbench), just be careful of how deep you go so you don't damage the reflecor.
I used silicone to mount the reflector to the aluminum LED, then just superglued the lens to the center cap over the reflector.
You can wire this up however you like, but I used some old heavy duty coiled microphone CB cord, reversed the grommet on the passenger side of the tailgate so it wouldn't pull through, and zip tied the end to the FabFour tire carrier. A 2 wire trailer quick disconnect allows quick removal for tire change/rotation. Of course shrink wrapped everything for water resistance.
Almost any 2" clearance/marker/tail light would work great for this application, but I wanted LED for the fast fast responce time (it's surprising how much faster than the filament bulbs this is) and needed a Luxeon/CREE style bulb for brightness for day use. Might have to try CREE bulbs for the 2 other brake lights now, but will still have to deal with the flasher problem with a module.
Old Feb 28, 2009 | 03:13 PM
  #4516
RedRockJk4x4's Avatar
Just installed Rubicon rock rails on my Sahara to replace the crappy plastic steps.
Old Feb 28, 2009 | 03:34 PM
  #4517
ndnatty's Avatar
Had it towed to the dealership after the transmission crapped out on me. Guess they are open on Sat. but don't have mechanics to work on it until Monday!
Old Feb 28, 2009 | 05:49 PM
  #4518
silvurback's Avatar
took the air dam and "X" stickers off
Old Feb 28, 2009 | 05:52 PM
  #4519
jd1066's Avatar
Put in my Woods evap canister relocation kit with the help of Paramaniac today at Jeepin Dad's house.
Tomorrow, weather permitting, I'm putting 3/4" spacers in the front.
JD
Old Feb 28, 2009 | 06:42 PM
  #4520
bigbluejk's Avatar
ummm. tomorrow I will finally install the factory bumps jeepindad sent me! thanks man! I also got the gears inspected and gear oil changed to royal purple Friday. The 5.13s have 500 miles now!!! BEST MOD EVER!!!! I love my gears!
