Class of 2012
I've started having issues with my tire pressure warning light coming on when my tire is not low. I figured the cold is making it seem a little low and then after warming up it would be fine, but it's not. I just had the air checked last week. Not sure what's going on. Other than that, everything is great here.
Have you looked into putting nitrogen into them?
Nitrogen molecules are larger than oxygen so your tire pressure will never change once you set it up,(oh, and no more dry rot. Nitrogen displaces moisture.) Also, nitrogen runs cooler than air, so your tires will last longer from less heat build-up.
There's only one down side to filling up with nitrogen.....airing down, you loose all the benefits of having nitrogen in there. Unless you have a nitrogen generator on your rig. : wink :
Just my 2cents.
our 12 is about to turn13000 weve had it on allthe trails around Slida Co.
Buenavista Co. added warn front bumper 11000 pd Q winch rock gards
on front rear axles Rubicon Unlt. 4 Dr. We bought it after we all most
slide Wifes Toy. over cliff Wife said we needed a jeep .
P.S. also have 88 YJ
8500 on mine. It's finally coming together. All my fenders and bumpers are now on, I'm just gonna save for my or-fab tire carrier, 2.5 x-factor, sleeves, gears and wheels/tires. My genright rear bumper fit pretty good with my nemesis flares but I need some larger meats ASAP now. I am going to paint my rear inner fenders today.
