Grill Mod
Old Apr 4, 2011 | 04:30 AM
  #941
debsJK's Avatar
After 2 attempts of this I found an adhesive that works....plastic weld from Autozone. I scuffed the inside with sandpaper, used rubbing alcohol and let it dry. While letting it dry I just rolled off the sticky white stuff with my thumbs. Used the black gutterguard and zip ties and so far 3 weeks and it's held up through rain, snow and pressure washing.
Old Apr 4, 2011 | 06:25 AM
  #942
jkrub2008's Avatar
NICE
Old Apr 16, 2011 | 02:29 PM
  #943
scicero1's Avatar
Originally Posted by dcirate25
I had to do my grill in pieces as well. It seemed to work better. I added some clips from the hardware store and wiretie accordingly.
As for screening, I used the gutter screening you use to keep leaves out.
Old Apr 17, 2011 | 01:57 PM
  #944
nickhaake's Avatar
Thumbs up
Wow, guys! Thanks for this great idea! I decided to go with the aluminum gutter guard from Lowe's while I had the grill off for the marker light flasher mad.
It was a bit time consuming trimming the aluminum and then feeding the cable ties through the cable tie holders and the aluminum down each row of the grill, but I'm definitely happy with the results!
Great mod!!!
Name:	Hickory Point-20110417-00083.jpg
Old Apr 17, 2011 | 02:52 PM
  #945
Just finished mine today!! Went with the expanded steel, primed grey and finished with silver metallic.
ID:	150996   Click image for larger version
Old May 10, 2011 | 01:53 PM
  #946
TJF87's Avatar
Was doing my grill mod today in orange (have a black 2dr) and came up with this for my taillights. Anybody see any legal issues with it? Can't see how it's worse then smoking them
Old Jun 6, 2011 | 01:03 PM
  #947
Colemanation's Avatar
Very cool and easy! I will be doing this soon
Old Jun 8, 2011 | 10:19 PM
  #948
DropkickPhoenix's Avatar
Just did mine last weekend. I have the mod bug thanks to y'all! Total cost 30$ but cutting the separate pieces was a bit time consuming and I recommend investing in tin snips if you do it that way. Took about 6 hours taking my time but I put on several layers of paint and removed the crappy backing off of the zip tie anchors and mounted them with gorilla glue. Looks pretty enough for me. Thanks for the write up!
ID:	169813   Click image for larger version
ID:	169814   Click image for larger version
ID:	169815   Click image for larger version
ID:	169816   Click image for larger version
Old Jun 9, 2011 | 07:43 AM
  #949
myke151's Avatar
Came out great.
Old Jun 10, 2011 | 03:22 AM
  #950
mabar's Avatar
I did mine yesterday. Used a one-piece "pet grille".
One-piece grill mod
I changed my mind and removed the Pet Grille and used YardGuard Hardware Cloth in plastic from Home Depot instead. 1/2" mesh squares. Can be installed either with the squares vertical/horizontal, or on a diagonal. I installed it as a diagonal pattern. I think the diagonal looks a little more "factory like".
Complete write-up here:
JK Wrangler Grill Mod using plastic Hardware Cloth
Mabar
ID:	170883   Click image for larger version
ID:	170884   Click image for larger version
