Marker light mod
Old Dec 17, 2011 | 12:09 PM
  #421
Nailit's Avatar
Just did this in about 20 min!! 10 min just to run to pep boys for connectors!!
Works perfect!! Cut black wire from marker and splice into out most white/grn.
Now I don't have to worry about changing lanes in 3 lane traffic and having other car try to merge into center lane with me b/c he was on side of me and couldn't see my blinker!!
Old Dec 17, 2011 | 12:56 PM
  #422
whitj's Avatar
Outstanding ideas. Bravo.
Old Dec 17, 2011 | 01:22 PM
  #423
timb04086's Avatar
Originally Posted by drexelpike
Nice job!
Maybe next model jeep will have read this and do it out of the factory.
You think they would have already done this. It's mandatory for Europe. It would make sense to have it done since it is a safety feature. It's all about saving the Benjamin's. Lol
Old Dec 18, 2011 | 01:02 PM
  #424
Black-Shadow's Avatar
Default Marker light mod
Originally Posted by seal20
Okay, as mentioned later in this thread, all you do is snip the black wire coming off the side marker and tap it into the outmost white/brown wire that leads to the blinker. Ya, exactly....it should have come from the factory this way.
Check out the pic....it's worth a thousand words on how I got in there and did it. It's really simple and probably even easier since I had the grille off.
Great thread, takes 15 minutes if your use to wiring up electronics. Only thing I wanted to add was the black wire you have to cut and leave hanging, I used a liquid tool grip dip to seal it, lol I didnt want any future fires.
Old Dec 18, 2011 | 02:28 PM
  #425
LLCOOLBEN's Avatar
Wow, that was easier than expected. It only took 15 minutes and now the people driving next to me have no excuse before I run them over.
Old Jan 19, 2012 | 08:42 PM
  #426
iggysrubi's Avatar
Just tried it on my 2011 rubicon, and it seemed like the relay wasn't strong enough because it stopped the turn signal from working
Old Jan 19, 2012 | 08:45 PM
  #427
rainmaker4171's Avatar
Default Great Mod
just need to look at what info is right... seems like a lot of opinions
Old Jan 20, 2012 | 04:38 AM
  #428
MikekiM's Avatar
I've done this in both my 2008 & 2011.. no issues at all.
Old Jan 20, 2012 | 05:05 AM
  #429
jwdanger's Avatar
If the front turn signals stopped working and the rear ones work just fine check a couple things:
1) Double check your wiring (If everything looks good check the next couple things)
2) Check to see if the bulbs are blown (This happened to me when I did this on my 08)
3) If you have the fast blinking signal on the instrument panel, make sure you plugged them back up behind the grill (Happened to me once and several other people)
There may be some other things to check but I am pretty sure these are the most common issues
Old Jan 20, 2012 | 06:34 AM
  #430
Pathdoc2's Avatar
I don't understand the purpose of this mod. What exactly does this do?
