My light solution
Does anyone know if the wiring configuration (orange and gray) is the same on the 2011? I know they changed the interior on mine a lot. My buddy has a 2010 and there are a lot of little differences. For example, he has two power outlets on his lower panel. I have one and where the other one would have been there is a clip for holding papers, maps, etc.
Originally Posted by SilverShift
:bump:
Thought I'd bump this with my own contraption I did this morning
Quite easy and I used butt connectors which was the only thing I had on hand, so it was good enough. Thanks for the write up!
Originally Posted by bfcerny
Just did it...FYI...nothing is the same...no bolts, no orange and gray wire (that I saw), and the wiring harness is 3x the size. The 2011 is different. I wired mine to my DC outlet stuck it on the same. I dont mind it being on at all times. Low draw. Off when the jeep is off. Getting the panel off is a MAJOR PITA hook and latch at the top and stiff plastic retainers all around...only broke two!
Can't get it to work!!!!! damn LED wires are too small for the splicers I think. I tried reconnecting a few times just won't work. My hands hurt from trying to work in that small space. Gonna take a break and have at it again.
edit: went and tried a few more times. all my connections were good. does this not work with 2010 JKs? I followed the write up exactly. hmmmmm
