My light solution
Old Jan 23, 2009 | 05:44 AM
  #41
Dr.McNinja's Avatar
Originally Posted by JulietKilo
I like the idea but the colored lights arent my cup of tea. That is all, didnt talk down to it, just said my piece. I am going to use this idea but with low lumens lights matching the dash and radio colors.
I was knocking you, just saying that I don't think the one color is ricer. At least not anymore than painting vent rings, or the dash. Now, if they had multiple colors, or flashed with your bass, then I might agree.
I just didn't want the hassle of an on-off switch. If you put resisters in, you might be able to tone down an LED to low enough, but my red ones aren't bright in person. Those photos are something like a 5 second exposure because it is so dark.
Old Feb 3, 2009 | 04:44 PM
  #42
micja's Avatar
I ran blue lights in the foot wells and one in the same location of the console as the original poster. I did put a switch in the center console facing forward that lights up blue so when i flip it on, it iluminates the cup holders well. I also made it dimable. Totally worth the time and the money for the cool factor.
Old Feb 3, 2009 | 06:49 PM
  #43
Firewire's Avatar
They all look great. Thanks for the wiring info. Huge help!
Old Mar 6, 2009 | 04:54 AM
  #44
mattyrayb's Avatar
Do you think it would be ok to lightly adhere a strip of window tint to the strip to keep it from being so bright so as not to lose lighting on the dash?
Old Mar 6, 2009 | 05:15 AM
  #45
cablecoffey's Avatar
KMB,
You mention the orange and white from the HVAC switch panel....question.
This refers to the location of the wiring bundle - correct, and not that the orange and white are part of the HVAC circuitry?
Reading that these are dim-able from the stock rotary dimming switch; I'm assuming that the reference the HVAC switch is that locations back lighting.
Old Mar 6, 2009 | 06:52 AM
  #46
mattyrayb's Avatar
I would assume that the wire is connected to the lights for the temp controls (which I would assume are dimmable)
Old Mar 8, 2009 | 07:02 PM
  #47
jd8100's Avatar
very nice
Old Mar 9, 2009 | 04:28 PM
  #48
KMB-JK's Avatar
Originally Posted by cablecoffey
KMB,
Cablecoffey,
When you have the front of the consol tilted forward you will see a large bundle of wires that plug into the back of the HVAC switches. Unclip it from the switches and look for the orange wire with the grey stripe. This is the wire you will connect the positive side of the strip to. Once you make that connection reconnect the bundle to the switch and make your ground connection. The light will then dim with the stock dimmer along with the rest of the dash lights. Follow the pictures and it should all make sense.
NOTE: The longer the LED strip the more light it will have. I used a strip with 9 LEDs. I would advise the 3 or 6 LED strip.
Old Mar 9, 2009 | 05:27 PM
  #49
Deviant's Avatar
damn that thing gets bright...wow!!
Nice job.
Old Mar 10, 2009 | 04:44 AM
  #50
Originally Posted by KMB-JK
Cablecoffey,
Thanks!
Already have the 9 inch ordered (I'll do this in a couple of weeks) perhaps I can overcoat them mildly to soften the sharpness.
Excellent modification!
