Old Man Emu 2" Lift Installation Write-Up
Old Jan 25, 2008 | 04:51 PM
  #21
Robar's Avatar
Originally Posted by bofer84
I would certainly go with the heavy duty coils, as i know i have the 4 door and bumpers are in my future at some point. Im just wondering how well this kit flexes, and rides on the road, as compared to others in its price range....ie BDS 3" Black Diamond, etc...
Like I said, I am going to check the flex next weekend, but I can say that the ride on the road is way better than stock.
Old Jan 26, 2008 | 02:43 AM
  #22
aldaman's Avatar
....................Now, I should note that we did this Old Man Emu 2″ lift kit install on a 2-Door Jeep JK Wrangler X that already had 33″ tires installed on it. And, when all was said and done, I can tell you that this kit yielded closer to 3″-3.5″ of lift and had plenty of room under the fender flares to fit up to a 35″ tire. The installation is extremely simple and can be done in about 2 hours using basic metric tools.
Fantastic write-up. I do have a couple of questions.
1) Opting for the HD version to be installed on a 4-door JK, would after aftermarket bumpstops be needed?
2) And are extended brake line brackets or longer brake lines needed if the overall lift may be ~3"-3.5"?
Thank you...
Old Jan 26, 2008 | 04:45 AM
  #23
TROUBLESHOOTER's Avatar
Very Nice. Looks like the front end is up where it needs to be. Nice level stance.
Old Jan 26, 2008 | 05:03 AM
  #24
Robar's Avatar
Originally Posted by benmar2000
Besides the trackbar questions.. What about control arms? How are the caster angles?
My lift is still pretty new. At this point I need to adjust my caster, but it is not bad just a little flighty. I am going to wait a few monts to see how much if any the springs settle before I consider upper control arms.
Old Jan 26, 2008 | 06:20 AM
  #25
wayland1985's Avatar
Cool. I've been waiting for this write up. What's all this about caster and stuff though? Is that somehting an alignment shop will take care of, or is this more complicated?
As for adjustable track bars, how much work is needed to dial them in right?
Also, where can I find more pictures. I kind of like those added fog lights.
Old Jan 26, 2008 | 01:08 PM
  #26
wayoflife's Avatar
JK-Forum Founder
So far, NotMySonsJK seems to be happy with factory caster on this lift. And, in my experience, people with 4-doors have less issues with wandering after a lift and if that's what you have, it probably won't be an issue for you.
Thank you...
1. No. From what I understand, the OME coils are rated as such that over compression should not be an issue.
2. No. The shock length have been designed to act as limiting straps and they will prevent you from over extending your brake lines.
All you need to do is recenter your steering wheel (if needed) and that's something you can do yourself in minutes and a 15mm wrench.
Adjustable track bars are very simple to set and you can find out how to do it by checking out my write-up here:
http://project-jk.com/jeep-jk-write-...-end-alignment
Last but not least, you can see a few more pics of this JK on its new OME lift at the bottom of the write-up.
Old Feb 13, 2008 | 12:14 PM
  #27
swampdonkey's Avatar
Comparing this to the TF HD BB, does the OME not come with new longer sway bar links? I did not see them pictured in WOL's writeup. With the 2.5 TF, it comes with new longer links. Just curious and trying to make up my mind! I will have bumpers and winch, so the HD version is what I plan on going wtih.
Old Feb 13, 2008 | 12:25 PM
  #28
Bluewaterrider's Avatar
Question 2 door medium springs??
ANYONE out there have the 2 door OME lift with MEDIUM springs front and rear??
Old Feb 13, 2008 | 12:59 PM
  #29
Wink Northridge Kit
If you’re looking to give your Jeep JK Wrangler a 2″-3″ lift and have no plans of ever going taller in the future, there’s only one true suspension lift kit you should consider and that is the one made by Old Man Emu. Being that the tallest lift that they make is an advertised 2″ lift, you can be sure that they do all that they can to make it the very best and have actually made a reputation for themselves for doing just that.
Retailing for about $650, the Old Man Emu 2″ suspension lift is by no means a ‘budget boost’ nor is it meant to be. As mentioned, this kit is a complete suspension lift that includes the replacement of your factory coils and shocks with ones that have been specifically designed and rated to offer the best ride possible.
You might know this already, but FYI If you purchased NORTHRIDGE4X4's advertised OME ''heavy duty kit" it comes with heavy duty front springs and medium rear springs.
Old Feb 13, 2008 | 01:19 PM
  #30
Northridge4x4's Avatar
Sponsoring Vendor
Not exactly.
OME has 2 HD Rear springs
OME 618- Heavy constant load 300 pounds which is what we include.
and
OME 620 Heavy constant load 660 pounds - These springs should never be sold. Way to heavy
David
