Old Man Emu 2" Lift Installation Write-Up
Old Apr 3, 2008 | 12:47 PM
  #51
derekls's Avatar
I am not sure about what to do with the rubi sway bar disco
but the kit doesnt come with extensions i dont think, although I have the JKS sway bar discos so I dont know if you dont already have extensions i suppose you would have to buy them
Old Apr 3, 2008 | 12:49 PM
  #52
Northridge4x4's Avatar
Sponsoring Vendor
So that package deal is for the HD? For some reason, that link doesnt give me much info.
The package deal is available in all the spring rates just specify that on the order.
If anybody ahs any other questions please feel free to ask.
David
Old Apr 3, 2008 | 12:56 PM
  #53
derekls's Avatar
Originally Posted by nukeman
I have the OME HD lift and the exact bumper as you, also with winch.
Initially I got 3.75" front, and 3.25" rear of lift. Added the RR bumper, winch, and full size 35" spare, and wheeled it a bit and it only settled 1/2" in the front, and the rear was unchanged. I added 3/4" spacers to the front, and it is very close, if not dead on, level.
I would't hesitate to install te HD kit, even if you never intend on running aftermarket bumpers, winch, etc. The ride and handling of the HD kit is significantly beter than stock.
Don't let the "HD" confuse you, the ride is actually quite soft and having taken mine wheeling on a few occasions I can say it flex's like crazy.
What about driveshaft wear if you wheel alot with the initial lift you get with the HD springs - if I remember correctly anything over 3 inches could call for new driveshafts, etc?
I feel the MD springs would be good enough unless you are going with some heavy aftermarket stuff..that weighs them down to the advertised 2.5 inchs of lift......
I have the Basic DX with smittybilt winch dont plan on any heavy heavy stuff so I went medium
Old Apr 3, 2008 | 05:30 PM
  #54
derekls's Avatar
Also I would like to note out that there is no Medium Spring for the OME kit. Just Light load and heavy according to the arb website.
Old Apr 4, 2008 | 09:58 AM
  #55
Ctimrun's Avatar
Originally Posted by Spillidge
Not sure if this has been covered but, can I run the stock Rubi wheels and tires with the lift? Or am I going to run into clearance issues and have to put on spacers?
You can run the stock wheels and tires no problem with this lift. There is nothing on the kit that changes anything to cause rubbing.
Old Apr 4, 2008 | 11:48 AM
  #56
Dustoff '68's Avatar
and what about centering the drive shaft...track bar relocation bracketes...adjustable brackets...is any of this stuff needed after one installs the 2" but really 3.5" OME lift? I want to know since it's the only lift manufacturer that I would even consider at this time...they are essentially the last ones out with a "budget" boost, and they have R&D'd the product to death, as well as studied all the rush to market budget boosts and discarded what they didn't like (most all of it), and borrowed what they did like (very little if any).
Old Apr 4, 2008 | 11:52 AM
  #57
Sponsoring Vendor
Nothing else is "required" but some of the stuff is nice to have.
Your axles will be offset 1/4" which is not horrible but not perfect. add $188 trackbar problem solved.
I have said it many tiimes and I still stick to my guns. I would rather be 1/4" off then put any drop dwon brackets on.
Its adjustable track bars or nothing IMHO.
David
Old Apr 4, 2008 | 12:01 PM
  #58
Thank you Northridge...btw...have you shipped my OME shocks? I may just go for the springs as well, but for now, the shocks will do.
Old Apr 4, 2008 | 12:03 PM
  #59
Sponsoring Vendor
Yep shipped same day your ordered.
David
Old Apr 4, 2008 | 01:15 PM
  #60
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
Originally Posted by Audiophiliac
I wanna see this kit in full flex. Pics please?
These aren't what I'd call "pretty pictures" but I'm fairly certain that this is fully flexed . Definitely fully stuck.
