Old Man Emu 2" Lift Installation Write-Up
Old Apr 4, 2008 | 10:09 PM
  #61
derekls's Avatar
Thanks for those pictures. My kit will be in on mon-tues and now I am way way more excited about my lift now than I already was! lol
Old Apr 5, 2008 | 06:01 AM
  #62
Bluewaterrider's Avatar
Question Which OME springs
Which OME springs did you get?? I am VERY interested in seeing a 2 door with the medium springs on the front and rear!!
Old Apr 7, 2008 | 10:37 AM
  #63
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
Originally Posted by Spillidge
Great photos Woods!!! Looks a lil stuck
Any photos of your JK on level ground. I would love to see the ride height with someone standing next to it for scale.
I need to show the girlfriend its not too high....
I have the HD lift, with very little added weight (don't even have a front bumper). I don't have any pics, but I figured out an idea that might help you out. You'll have to do a little work though. I took a measurement between the lower and upper bump stops. The distance is 5.5" both front and rear. If you take a jack and lift the frame till you are at this distance, it would be a great way to show your girl the real height.
Here is a guick question.
If the shocks act as "limiting straps" would you not have better flex with say the Teraflex BB?
It seems that OME has not addressed brakeline length and swaybar links. Does this mean that the shocks limit the amount of suspension travel?
The reason I am posing these questions is I am torn between the Currie long travel kit and OME.
Looks like travel is limited with the OME but you can run 35's where as the travel is extended with currie but you can only run 33's.
Any comment???
thanks to all in advance!!!!!
I think to get the answers that you are looking for, you'll need to add some detail to your questions. But, I'll give this a shot.
I'm assuming that you are asking about the Teraflex BB with longer shocks. The TF BB uses bump stop extensions. This reduces the amount that your suspension will compress. The OME kit does not. Assuming that both kits raise your JK the same amount (which they do not), the TF kit will allow larger tires. I'm not sure about droop, as I don't know the length of each shock. But for arguments sake, the shocks would have to be at least two inches longer (extended) to have equal flex to the OME kit. I purchased longer swaybar links for the back and moved the back links to the front. Especially If you have an electric sway bar disco, I'd recommend this change. And yes, an educated guess, is that the shocks limit the droop.
If I was running 35's, I'd have to mod the fenders for sure. My 33's are already rubbing too much.
Is it true that the Currie long arm is limited to 33's? That seems strange to me. My neophite opinion is that the Currie kits and OME kits are apples and oranges. From what I understand the Currie kits are better designed for driving fast through the dirt and desert. I don't know a thing about the long arm, but the Currie lifts that I've seen have dual rate springs. Great for covering ground fast, but not designed for crawling where flexing is important. I think the OME kit has VERY good flex, for what it is. And if crawling is what you want to do, then go with the larger tires.
my 2 cents
Old Apr 13, 2008 | 09:59 AM
  #64
Bradlybob's Avatar
Veteran: Navy
I've read recent grumblings from the XJ guys that OME has outsourced the production of leaf springs and quality is suffering. Are the coil springs still of high quality? Anybody heard anything?
Old Apr 13, 2008 | 01:42 PM
  #65
Lightbulb Coils good
I have asked the same question and Mark in technical in the USA said that the coils are still made in Australia, while the leaf springs are now outscourced in Malyasia.
Old Apr 14, 2008 | 07:37 AM
  #66
Northridge4x4's Avatar
Sponsoring Vendor
No OME has been using the same "coil" spring MFG that they have always been using.
Old Apr 21, 2008 | 03:15 PM
  #67
nthinuf's Avatar
Default OME front shock tightening
A quick question that hopefully some of you more mechanically inclined folks can help out with.
On Step 15 of the install write-up,
Grasp the Old Man Emu front shock can firmly with one hand and then secure the mounting stud nut in place using a 16mm wrench.
Are these really only supposed to be hand tightened?
Both front shocks are still very loose and can be wiggled back and forth and turned 360 easily. As these shocks do not have a second location to place a wrench (like the stock shocks), I can't seem to find a way of tightening them down any more. Holding with one hand and using a 'strap' wrench I picked up do not work, and I'd rather not try a metal oil filter wrench unless I can't come up with other options.
Am I overlooking something simple here?
Thanks
- Thanks for the heads up guys. As much time as I spent trying to tighten those up, I never noticed the top of the post for the second wrench.
Stupid little things like this are frustrating, but I'm having fun working on and learning about my jeep!!
Old Apr 21, 2008 | 03:28 PM
  #68
BaltChief's Avatar
On Step 15 of the install write-up, Are these really only supposed to be hand tightened?
Thanks
Are you talking the top mounts in the front? If yes, then you have a cfew options.
You can get a deep socket with a long extension and go at from the top through the engine compartment.
you can get a shock tool at most pep boys or auto stores.....
you can be patient and go in from the side under the wheel well with a thin wrench......
it will tighten up, do not overtighten or you will screww up the bushings.
Old Apr 21, 2008 | 03:42 PM
  #69
Sponsoring Vendor
The top of the shaft is 8mm. Put a wrench on it and this will stop it from turning and you will be fine.
Get it nice and snug.
David
Old Apr 22, 2008 | 01:00 PM
  #70
chucktuna's Avatar
I did mine today...pretty easy, but just a few things I noticed.
I loosed up a few more things than were suggested.
Mainly brake lines and sensor wires. NO way I was gonna get the new springs back in
without lowering the diffs more than these thing would allow.
Sensor wire holders:
And a brake line in front:
I also only took 2 of the 3 skid plate bolts out. Loosed up the 3rd real good, and just let it hang:
Also I think I'll go with some extended brake lines.....this is at full droop, limited by shock:
I'm waiting for the track bars Friday so I dont have it all together yet.
But it site up nice so far.
chuck
