Winch mount W/factory bumper
Warn M8000 winch. Harbor Freight mounting plate. Winch controller is hidden behind the bumper. Clocked the end of the winch so the free-spool lever would clear both the crossmember and metal bumper w/o cutting. Didn't have to cut or lengthen any wires... everything fit perfect!
This is exactly how I want my Sahara to look when finished. Air do you have any additional photos of your install?
Just thought I'd post mine up again
Attachment 512435Attachment 512436Attachment 512437Attachment 512438
When I did mine, I relocated the brake booster. I simply cut the existing bracket off the frame, mounted it under the hood and was able to just pull apart the hose and reconnect a shorter existing version. Note: I have a 2015 rubi. No problem with the disco, but the trimming and adjustment of the winch plate and the bumper took some test fitting.
