OK bs
Old Mar 25, 2011 | 08:13 PM
  #4531
interceptor_1972's Avatar
Originally Posted by u-joint
I believe he did.
Cool . Torquing the pitman arm to 180 ft lbs - 185 ft lbs is a royal pain!!
Old Mar 25, 2011 | 09:44 PM
  #4532
PainKiller's Avatar
Originally Posted by interceptor_1972
Did you go back to a stock pitman?
Yes I took the drop pitman off and re-installed the stock pitman arm the steering wheel was off a little but I adjusted it and it drives totally different now. just a slight bump steer but really not noticeable at all , I drove around and hit a the bumps that usually makes me have low speed violent DW and NO GO ! ! hopefully it is fixed thanks for all the help on the geometry and engineering tech. Manoj and Jason was a life saver with the socket he let me borrow thanks guys
Old Mar 25, 2011 | 09:50 PM
  #4533
PainKiller's Avatar
YES it is , I took the trackbar off on the drivers side and then used a air impact then found a good spot for the torque wrench to fit and got it torqued down, torquing the draglink to the stock pitman arm one is harder to torque than the drop pitman arm but I just tightened it up as much as I could with a wrench and then found a place where the torque wrench would barely fit and went two clicks at a time but it worked out FINALLY
Old Mar 25, 2011 | 10:08 PM
  #4534
Originally Posted by PainKiller
...I drove around and hit a the bumps that usually makes me have low speed violent DW and NO GO ! ! hopefully it is fixed ...
Time to stick the SS back on . I'm about 80% positive on making it up there this Sunday. Will let you know a definite time tomorrow
Old Mar 25, 2011 | 10:21 PM
  #4535
PainKiller's Avatar
That would be GREAT ! !
Old Mar 25, 2011 | 10:23 PM
  #4536
PainKiller's Avatar
Ahhh.... the drag link and tie od are too close and the zert is touching... gotcha.
That sucks
took the zert out for now, until i can figure out a solution and talk to david to see if there is any others with the same issue. I will run to NAPA tomorrow to see if they have a plug that will fit into the zert hole.
Old Mar 26, 2011 | 04:33 AM
  #4537
Hulk's Avatar
Good morning guys!
Old Mar 26, 2011 | 04:41 AM
  #4538
Coondog33's Avatar
Originally Posted by Mean.Green
Good morning guys!
Yes it is...soccer game #1....
Old Mar 26, 2011 | 04:46 AM
  #4539
Hulk's Avatar
Man I can only imagine when my son gets old enough for sports lol it's hectic enough
Old Mar 26, 2011 | 04:49 AM
  #4540
DiFfErEnT's Avatar
Originally Posted by bigcjeep
You"ll be fine.. I have ran either not top or just the front freedom panels for the past 2 weeks.. Yea its a little chilly at 730am trip to work, but thats what jackets are for..
I got my first rain in the Jeep last night.. ahhh the seal has been broken.. hahahha
hahahah you think its cold at 0730 you should go to work at 0500....LOL it really cold then!
