2012 driveshaft problem with auto trans
WOL - I (and probabaly many others) appreciate your knowledge and first hand experience w/ this subject. It really sucks that the 2012's are going to take a lot more $ to lift properly than most of us expected.
But to summarize - to 'properly' lift a 2012 JKU for the long haul (many many years of service) we should:
1. Relocate the exhaust pipe (AFe Y-pipe or Teraflex spacers)
AND
2. Install an aftermarket front drive shaft
If both of these are done for say an AEV 3-1/2" lift, we should be good-to-go for the long term, right?
Thanks
AND
Thanks
AND
Thanks
AND
Thanks
Well I solved everyone's problem. Pretty easy fix.... Just take your exhaust completely off at the headers. Voila! A little louder than stock but what the hell?
On a serious note can we get away with just buying a new drive shaft and the Tera Flex spacers and be good to go? This thread is getting me all effed up in the head on what to do about solving this problem.... \What drive shaft should I be looking at with my 2012 auto slush box?
So tell me please, what is there about an aftermarket drive shaft that will prevent the severe drive angle? Does a CV (double cardan joint) improve the angle problem? What will prevent the u-joint from failing?
I'll admit i don't know jack. My dealer has been awesome thus far in the ordering process and is installing my AEV lift for me and allowing me to roll the price of the lift into the 0% financing they are running. I'm trying to decide if i need to add an aFe pipe and coast drive shaft to the build list for them. I appreciate all of ya'lls help.
never said that a double cardan shaft will improve anything. i just said that leaving the factory shaft will cause the cv boot to fail sooner than later and that will effectively kill the shaft. if you have too much lift, you will most likely end up seeing some binding of the double cardan and or get vibrations. assuming you get a good shaft with spicer or neapco joints, they will not fail but, any vibrations you may get from the steep angle may cause other issues like a busted t-case.
