2012 Lifted - Exhaust Issue
Old Jan 17, 2012 | 06:25 AM
  #21
lensstj's Avatar
agreed. i would get the new shaft as you'll need it anyway. your drive shaft will now be sitting at a steep enough angle that the cv boot at the output shaft will be in a constant state of pinch. this will ultimately result in it failing sooner than later. being that a new drive shaft will not have a slip shaft boot, even if you still hit the exhaust crossover, it won't be a big deal. if it's really a problem for you, the TF spacers are cheap and will remedy that too.
On a 2 door this is more true then on a 4 door. On a 4 door you can get away with a 2.5 lift and the stock shaft for a long time....
Old Jan 17, 2012 | 06:44 AM
  #22
Full-Traction Suspension's Avatar
Former Member
No, the front end of the JK is the same.
You can run a 27.5" long shock and a replacement 1310 U-Joint driveshaft and not need to modify the stock exhaust.
We run JE Reel 1310 w/replacement yokes on the 2012 kits.
Old Jan 17, 2012 | 06:45 AM
  #23
wayoflife's Avatar
JK-Forum Founder
up front on a 2012, it makes no difference if you have a 2-door or a 4-door as they are the same and will have the same problem even if you just have a 2.5" lift. the problem comes from your shock length and, so long as what you have is only stock length or there abouts, you will be fine regardless if you have a 2-door or 4-door. if you have extended shocks, you will still have issues with the slip shaft boot making contact with the exhaust crossover. regarding the cv boot, it may last for a while but, it will still be in a greater state of pinch and i do have my doubts as to just how long it will last. time will tell i'm sure. in the rear, you do not have to change out the drive shaft on a 4-door but, you will want to on a 2-door as you will have drive line angle issues.
Old Jan 17, 2012 | 07:03 AM
  #24
ALEXANDERJASON's Avatar
Originally Posted by Lotus F1
Ok makes sense... from reading your initial post it was not clear and could cause some confusion, as the stock 2012 will not have this driveshaft/exhaust issue when 2.5" or lower.
stock 2012 JKU here with torn boot using Teraflex 2.5"bb and stock shocks with adapters.
buy the exhaust spacers!!
Old Jan 17, 2012 | 07:13 AM
  #25
surfndav's Avatar
I just put a 3" TF lift on my 2012 Rubi. Springs, shocks, Rear track bar relocation bracket, I also did the exhaust spacers. In addition to the kit I put on new TF lower control arms, new front track bar and wheel spacers. I have gone out wheeling twice and I'm amazed at what this set up can handle. The only thing I worried about is the angle of the forward drive shaft coming out of the transfer case. Can you be more specific about this statement "We run JE Reel 1310 w/replacement yokes on the 2012 kits." I am new to all this, this is my first Jeep, and my wife is about to kill me for all the money I've spent so far. The only thing that would be worse than spending more money now is being involved in some sort of emergency situation that might include tow trucks and emergency repairs. So any advice that would help me avoid that situation would be helpful.
Thanks
Old Jan 17, 2012 | 07:20 AM
  #26
wayoflife's Avatar
JK-Forum Founder
Thanks
the factory drive shaft uses a rzeppa joint at the output shaft and, if you look at this carefully, you will notice that the angle of the shaft coming out of it is significant. this angle is effectively pinching the rubber cv boot and, over time, will cause it to fail. how long will it take to fail? hard to say for sure right now but, if it's anything like the 2-door rear shafts, maybe in about a year or so depending on how and what you drive on. when it starts to go, you will see grease up and long the bottom of your tub as it spits out of the boot. when you see this, you need to get a replacement right away. if you wait too long, you will start to hear a ratcheting sound coming from the joint and when that happens, you're done. needless to say, you'll be okay for a bit but, it is a problem you'll need to address sooner than later.
Old Jan 17, 2012 | 07:27 AM
  #27
TeraFlex's Avatar
Sponsoring Manufacturer
Originally Posted by midwesterner
All,
I just installed a Teraflex 2.5 coil lift on my 2012 JK Unlimited. From reading other threads I knew the drive shaft would be close to hitting or hit the exhaust at full droop. Well after getting everything installed my drive shaft starts hitting the exhaust about 3/4" from being fully extended.
My question is how to fix it.
1) Exhaust Spacers?
2) New Y Pipe?
3) New Coast 1310 Drive Shaft?
I'm leaning towards a new drive shaft if it will give me the clearance i need. Does anyone know what the diameter of the Coast 1310 drive shaft is at the point it crosses over the exhaust??
I would prefer not to mess with the exhaust of this nearly new vehicle to avoid any warranty issues if I ever have any engine troubles.
Im anxiously awaiting your opinions.
Thanks!
You can run the exhaust spacers and be fine. TeraFlex 3" and taller kits require the exhaust spacers/front driveshaft. Here's a video that explains it better.
http://www.youtube.com/watch?v=oKBlEpMaJC4
Old Jan 17, 2012 | 08:15 AM
  #28
Former Member
Thanks
I mentioned JE Reel because thats what we use on our kits. If the driveshaft you purchase has bigger diameter shaft than a Reel, It will not clear the exhaust. I've had the pleasure of replacing stock driveshafts on the trail, its not fun.
I would rather replace the weak/prone to breaking factory shafts before I hit the trails.
Old Jan 17, 2012 | 08:34 AM
  #29
surfndav's Avatar
"the factory drive shaft uses a rzeppa joint at the output shaft"
This is what was confusing me. I have been looking at after market drive shafts and not seeing the same type of joint at the transfer case. I now understand that the after market shafts use a conventional yoke and u joint coming out of the TC. Am I right on this? If so I can see how this would take care of the problem with the severer angle with the stock DS at the TC. I guess I'll be getting a new DS in the near future. Thank god money grows on trees.
Old Jan 17, 2012 | 12:07 PM
  #30
midwesterner's Avatar
Default New drive shaft it is!
After considering all the information I decided to go ahead with the new Coast 1310 drive shaft. It is 2" in diameter versus about 4" for the stock drive shaft. This should net me enough clearance to eliminate any exhaust contact. I ordered it today from everyones favorite vendor. He tells me they are a bit behind and it will be a couple of weeks before it can ship. Thats ok as dont see any wheelin for a couple months anyway.
Thanks for everyones input; it is greatly appriciated!
