2wd to 4wd conversion help!
Old Jun 25, 2013 | 06:21 AM
  #41
JK yeti's Avatar
Originally Posted by jaker t5
No its metal on metal , I felt the same way to so I put some rtv between them have not had a issue
And if you look at the very bottom there is actully a hole there
Thanks Jaker! One more question, where the heck does this C Clip go? Is it part of the shifter cable?
Old Jun 25, 2013 | 09:07 AM
  #42
jaker t5's Avatar
Attachment 471703
It goes on the out put shaft from the tranny and that clips goes inside the input shaft to hold the two together
Old Jun 25, 2013 | 06:29 PM
  #43
JK yeti's Avatar
Ok so it's kinda like sandwiched inside the output shaft? I'm sure when I get under there it will make more sense.
Old Jul 1, 2013 | 06:11 PM
  #44
JK yeti's Avatar
???^^^ am I right? Anyone got a picture? Or reference?
Old Jul 6, 2013 | 02:13 PM
  #45
JK yeti's Avatar
QUESTION!!!
Can i use the 2wd transfer case bolts that mount to the transmission or do i need new ones??
Old Jul 10, 2013 | 08:25 PM
  #46
JK yeti's Avatar
Old Aug 25, 2013 | 12:07 PM
  #47
JK yeti's Avatar
Old Sep 3, 2013 | 08:00 AM
  #48
Timecloud's Avatar
Hows the build going? I keep finding newer threads. I am converting my JK as well. I'm glad I found this thread just for your list. I have the F/R Driveshafts and complete front axle from a 2010 JK unlimited sport. How can I tell what the gears are currently?
Hope we can help each other.
Old Sep 3, 2013 | 11:23 AM
  #49
JK yeti's Avatar
You can jack up the rear, mark a spot on a tire and spin the tire 2 full rotations, mark a spot on the driveshaft and count how many times it goes around during the 2 tire rotations,
A little more than 3 turns is 3.21's
A little less than 4 is 3.73's
And a little more than 4 is 4.10's
Old Sep 3, 2013 | 08:30 PM
  #50
jaker t5's Avatar
Way to go , not as bad as you thought
Are you done with it now
