4" Lift
It's a good thing Kjeeper is here for you, so he could point out one item for you then huh? However, is that really the reason you considered them to be a better option? He also pointed out ride quality was essentially the same as well. I bet you learned something there that you didn't realize prior huh?
Keep up your laughing, and acting like a clown with your responses. We both know you can't answer the question, otherwise you would have jumped on the opportunity the 1st time I asked. I like clowns....they make me laugh also and you seem to have the ass clown act down pat.
You getting mad bro??
I agree on the CA's. I prefer adjustable arms also but OP was locked into Quadratec due to the mishap / credit. Since he is also a newbie to Jeeps, doesn't make sense to complicate matters by directing him to piece-mealing a kit. JKS comes with high steer, pre-set extended length beefy control arms to their 3" lift, comes with good mid-level Fox shocks and springs, is a good brand, you can still run the stock front driveshaft, and all for less than $2k. They even throw in their front discos.
It's pretty obvious JKS is pricing their kits very aggressively to tap market share since they were late to the game in offering suspension kits.
For mr redroller, I guess he prefers the whack Mopar 4" kit that comes with crap parts other than the Fox shocks, trackbar brackets, and probably the driveshaft. BUT no high steer kit, no trackbar, whack extended length stock control arms, AND THE KICKER is it comes in at $2364 ??!!?? You take away the drive shaft to get in < $2k territory, and it's absolute crap compared to the JKS.
The Synergy is nice but at $3120 that's a pretty decent chunk of change and you still have to add shocks. So that's another $400-$500 easy.
Out of all three kits (5 if you even include the Teraflex and AEV), the JKS at $1975 puts all the others to shame. Hell, with the extra credit he has he can easily add adjustable front and rear uppers since it sounds like he already bought the Adams shafts...
Not directed to anyone in particular but now I remember why I've been avoiding threads like these to try and help a newbie out.
The Mopar comes with Fox PERFORMANCE series dual reservoir shocks which have been tuned by FOX for this lift, the JKS comes with Fox Adventure series off the shelf aftermarket shocks. Go check out the price difference between the Performance series vs the adventure series. Apparently alls you really care about is that it has the FOX name printed on them. The Performance series cost twice as much as the Adventure series Fox shocks.
Performance Series
https://www.northridge4x4.com/part/s...ear-4-6in-lift
Adventure Series
http://www.quadratec.com/products/16...Nh1hoCJjfw_wcB
The Mopar kit additionally has the FOX performance series steering stabilizer which the OP was originally interested in purchasing. The JKS comes with none.
The Mopar kit comes with a high steer kit drag link flip kit, something you said multiple times now that it doesn't. The same as the JKS kit.
The Mopar Kit comes with replacement extended brake hoses for all four corners, the JKS comes with inadequate for a 3.5" lift brake line relocation brackets.
The Mopar kit comes with a Dana drive shaft with Spicer joints. The JKS comes with none.
The Mopar kit comes with 4 replacement sway bar links, the JKS comes with the Front JKS quick discos and NOTHING for the rears.
The Mopar kit can be found all over the web for $1850 and Q-Tec price matches.
Yes, the JKS kit comes with a front adjustable Track bar, which requires an additional front track bar bracket to be welded in place to mount it with that lift. 'Welding required for front track bar mount gusset installation"
Both come with 4 control arms with "OE style" bushings.
Both come with rear track bar relocation brackets.
The Mopar kit provides a Warranty that if the lift is determined to cause damage to your OE parts, then the OE parts will be covered by the lift's warranty. The JKS kit takes no liability if damage is caused to the OE parts due to their lift.
This silly game you want to play is pretty dumb but since I've seen the nonsense you've been spewing it's understandable why it continues to spew because that's exactly what it is "nonsense".
I'm not so sure what you hate so much about Mopar but let's get the facts straight if you want to compare it to the JKS lift. The Mopar comes with Fox PERFORMANCE series dual reservoir shocks which have been tuned by FOX for this lift, the JKS comes with Fox Adventure series off the shelf aftermarket shocks. Go check out the price difference between the Performance series vs the adventure series. Apparently alls you really care about is that it has the FOX name printed on them. The Performance series cost twice as much as the Adventure series Fox shocks. Performance Series https://www.northridge4x4.com/part/s...ear-4-6in-lift Adventure Series http://www.quadratec.com/products/16...Nh1hoCJjfw_wcB The Mopar kit additionally has the FOX performance series steering stabilizer which the OP was originally interested in purchasing. The JKS comes with none. The Mopar kit comes with a high steer kit drag link flip kit, something you said multiple times now that it doesn't. The same as the JKS kit. The Mopar Kit comes with replacement extended brake hoses for all four corners, the JKS comes with inadequate for a 3.5" lift brake line relocation brackets. The Mopar kit comes with a Dana drive shaft with Spicer joints. The JKS comes with none. The Mopar kit comes with 4 replacement sway bar links, the JKS comes with the Front JKS quick discos and NOTHING for the rears. The Mopar kit can be found all over the web for $1850 and Q-Tec price matches. Yes, the JKS kit comes with a front adjustable Track bar, which requires an additional front track bar bracket to be welded in place to mount it with that lift. 'Welding required for front track bar mount gusset installation" Both come with 4 control arms with "OE style" bushings. Both come with rear control arm relocation brackets. The Mopar kit provides a Warranty that if the lift is determined to cause damage to your OE parts, then the OE parts will be covered by the lift's warranty. The JKS kit takes no liability if damage is caused to the OE parts due to their lift. This silly game you want to play is pretty dumb but since I've seen the nonsense you've been spewing it's understandable why it continues to spew because that's exactly what it is "nonsense".
Stiffer ride than the other lifts mentioned out there? Doubtful, subjectable and debatable definitely, just stiffer to when reference if they provided a 2 door specific version of this lift.
Personally, if you were originally interested in the Mopar 4in lift I wouldn't let the differences between a 4 door vs 2 door version stop me.
Add a front adjust track bar ($200-$300) to the lift, some front geo correction brackets ($100-$150) and then ask Q-Tec to do a price match and you have a complete lift which addresses all major concerns and is within your original budget.
Total Price: $1900+$300+$150= $2350
(8) Replacement Adjustable control arms all the way around as Dirtman suggested are nice but also tend to be very expensive and you also need to have someone that knows what they're doing to dial in the proper lengths to adjust them for you.
Here's some reference links you can use for price matching.
Mopar P/N: 77072353AB
http://www.moparpartsdiscounted.com/.../77072353.html
http://www.factorymoparparts.net/oe-mopar/77072353ab
Also, it comes with the nice Jeep logo crate.
Shocks that are "tuned" for a kit is just marketing and really not a benefit. This is a trend that is going around to make you think you are getting something special. The OP is already pushing height wth 35's on a 2 door not sure why he would need more height and a stiffer ride running 4 door coils. 4" of lift typically means running longer travel shocks, longer travel shocks typically = more articulation and axle shift which typically means you need more misalignment from the control arm joints. The Mopar kit uses factory style joints that is going to put more stress on the factory joints. I would not worry about the frame side but I may have some concerns about he axle side over time if you are running it hard. The control arms on the Mopar kit are also rather light weight in construction using a small diameter tube. Bigger tubes typically = more strength. Again low strength and very little misalignment of the arms can also cause the arms to bend if you are pushing the jeep.
The drag link flip re uses half of the factory link which is known to be weak and prone to bending. The Mopar kit uses fixed sway bar links instead of adjustable so you can fine tune your position of the sway bar. It also has fixed bump stop extensions so you are likely not going to maximize your articulation by using them. Cam bolts for caster corrections is a poor solution. No limiting straps like the old Mopar kit offered to protect those fancy shocks.
This kit is actually a pretty bad downgrade from the earlier Mopar 4" kit which was one of the most complete kits on the market. Its nice that it comes with the driveshaft, fancy fox shocks (not needed and is just for the bling factor), and addresses the need for high steer and the rear roll center. After that leaves much to be desired unless you are just installing the kit on a daily driver that does not see anymore then some dirt roads once in a while.
OP I have never seen you mention that cost was a factor or what you are planning on doing with your jeep which would have an affect on what kind of kit you should be looking at.
Last edited by TheDirtman; Feb 4, 2017 at 07:34 AM. Reason: Got confused with another thread
Yeah, Quadratec needs to correct their website then....
The link you posted ---> Synergy Manufacturing 4" Stage 3 Suspension for 07-17 Jeep® Wrangler & Wrangler Unlimited JK | Quadratec
.....is Synergy's #: 8023-30 which is a 3" lift only. Not 4" which Quadratec has it incorrectly listed as.
The real Synergy 4" is this one @ $3120 with no shocks ---> Synergy Manufacturing 8023-40 4" Synergy Stage 3 Suspension System for 07-17 Jeep® Wrangler JK 2 Door | Quadratec
...add another $500 for the Fox entry level shocks and now it's $3620
Maybe he should have just gotten the ICON. Since there are only 1 (maybe 2) people I know of running ICON (however they are running their coilovers), there won't be anyone here to talk smack about their conventional spring/strut setup lol
Bingo. Aside from what I and Biginboca already mentioned earlier, Dirty's post covers the rest on why that Mopar kit reaks worse than fumunda cheese.
Like I said roller, try not to get a brain aneurysm trying to analyze all of this lol...
G'day mate lol
Yesterday I spoke with FOX to understand the difference between the 2dr (pn 103) and 4dr (pn 102) rear shocks.
- The only difference is internal valving (mounting and length are the same)
- The 4dr shock is slightly stiffer that the 2dr (one step more low speed and high speed compression damping)
- Compared to the off-the-shelf FOX shocks you can buy for 0-2in lift, the stiffness of the MOPAR shocks is lower. So the standard FOX JK shock is stiffer than 4dr shocks in the MOPAR kit.
- For their aftermarket shocks, FOX does not differentiate between the 2dr and the 4dr for their shocks. MOPAR made a custom tune for both the 2dr and 4dr JKs and created MOPAR specific shocks for the lifts. This means you can't buy the "MOPAR tuned" FOX shocks for the 2in lift from FOX. They can only be purchased through MOPAR.
I'm also glad everyone is spending their time focusing on trying to pick the Mopar lift apart. Would we like to move to the other lifts and do the same as well, or is it just Mopar that interests everyone? I haven't seen a perfect lift or a perfect vendor, so it's not hard to do if you want to really focus on trying to pick apart one particular vendor with all the items you personally seem to have a problem with, which have no substantial real world data supporting it and is just all based on your personal opinion/observation.
I also said the Mopar kit was one of the more complete kits available and provided the additional items that would be needed, we can add some limiting straps in as well. I never said it was the "perfect" lift. You want to go into all the additional items on the JKS kit that are needed and see where that price tag goes? We can do the same with the Synergy stuff as well and go into all their joint related problems and rebuild/maintenance that may be needed. Gonna need some straps there as well. This will be fun.
Adams driveshafts = Lifetime Warranty on the Welds and Tubing if they break due to torque. All other Components have a One Year Warranty against any defects.
JKS = Up to 5 year / 100k limited lifetime warranty.
OP (if going this route) will be installing on a brand new 2017.
Mopar warranty???? 1 year? If that?
I win. Next!
I win. Next!
