AEV Drop Bracket BS
Old Nov 20, 2013 | 07:39 AM
  #41
DJ1's Avatar
DJ1
Former Member
After having these brackets sit in the garage for the last year, I guess I'll finally slap these bad boys on and see what I've been missing
Old Nov 20, 2013 | 12:58 PM
  #42
twoxstreem's Avatar
They work!
Old Nov 21, 2013 | 07:46 PM
  #43
RubiconGeoff's Avatar
Originally Posted by Dr. Satan
I guess what I'm getting at is the AEV instructions say, "THIS INSTALLATION IS BEST PERFORMED WITH ALL FOUR WHEELS ON THE GROUND"? I don't necessarily have to tighten or retorque the control arm bolts to put this all back together, put the wheels on the ground, and THEN install the drop brackets? Did anyone install these drop brackets while the front end was apart and the Jeep was on the jack stands?
Follow the instructions. This is the quickest and easiest way to install them.
Old Nov 22, 2013 | 04:42 AM
  #44
Dr. Satan's Avatar
Well. I put the Jeep back together AND then installed the brackets. I think that it could have been done while the Jeep was apart. I had 6 ton stands under the frame and 3 ton stands under the axle BUT I think it was SAFER to install these with the wheels attached, the Jeep on the ground, and one side at a time.
Thanks for the replies.
Old Nov 22, 2013 | 04:50 AM
  #45
kjeeper10's Avatar
Vet Army
You do not need to remove the tires. I swapped AEV to Rancho brackets in around a 1/2 hour myself.
Old Nov 25, 2013 | 05:47 AM
  #46
BuckLisa's Avatar
Much mores stouter! Have you seen TNT customs drop brackets? Talk about gnarly!!
Old Nov 25, 2013 | 10:42 AM
  #47
Rancho's Avatar
Sponsoring Manufacturer
I hadn't seen theirs yet. You are right, gnarly.
Old Dec 1, 2013 | 05:06 PM
  #48
BuckLisa's Avatar
Yours are awesome , just showing what a smaller company is doing from my research.
Old Dec 1, 2013 | 05:18 PM
  #49
Sahara Lee's Avatar
The Rancho version of the correction brackets come with a replacement bolt. I used a cut-off wheel to remove the factory bolt. Not enough patients for the Sawzall.
http://gorancho.com/assets/instructi...Revision_A.pdf
I've had the Rancho 4" Sport Lift on my 2010 Unlimited Sahara for almost a year now. The brackets have always been included with Rancho's 4" Sport Lift. They really work.
Wow! Just noticed that dent in my oil pan.
Old Dec 1, 2013 | 09:03 PM
  #50
bombout800's Avatar
even though the rancho brackets seem to be built stronger, wouldn't the aev still seem to be the better choice? Better flexibility with lift height and pre drilled for 2.5, 3.5, and 4.5. Is the rancho specifically set for 4" but can work with 2.5-4"?
