Coilovers - worth the hype?
Here is a pic of right when I got finished and putting it back together. I am running a rear 3 link also.
Yes but i mean barely, your brackets are part of the frame. I redid the whole frame section. With the towers still in the frame its not bad to fill in and box the elements out. I went thru the frame at 15 degrees inward and also forward lean if i recall. My shocks are thru the floor where yours are more so thru the wheel well body if im correctly recalling. Filling in the floor is a bitch. I do still have rear seats also and a fuel cell behind my rear seat all in a 2 door.
I might as well add to this thread.
I just priced out ICON coilovers and brackets. The ones that are 4.5 to 6" lifted.
I can't find a single review of them, but ICONs have an awesome reputation in the off-road community.
Near as I can figure out, all the bolt on coilover kits have similar mounting brackets setups, so the main difference is going to be the coilovers. Icon coilovers are known for durability.
Someone has to be the first to review, so it might be me.
Right now I'm running a RJ60 rear and a PR44 front. In a yet I will probably upgrade to full float rear and 60 front (Mopar probably), at that time, I may convert to a full weld in bracket and see if I can squeeze outboards in the rears.
You said DD and that is the Key word to me. I myself did a 2008 JKUX build with 4” Rockroller lift, with most of the Tie rod and drag link accessories. I also ran 33” With 2.5 Back spacers all the time. This ended up costing me about 1500+ a year in replacement parts maintenance IE: ball joints, tie ends, power steering gear box etc. And I wore out those fancy $600+ rebuild-able ball joints twice and once with the Moog ends. Just driving around town normally.
Do you have any ride height pictures with wheels on?
Coilovers are not hype but I think the better question is, to ask if the cost is worth the gains. In my opinion It all boils down to your available cash flow and if you are willing to part with it for X amount of improvement. I say this same thing in many threads that ask the question is X better than Y.
My buddy who has had a stock jeep for 3 years because he cant even afford to put spacers on it is now telling me he is thinking about going coilovers. Seriously?
Coilovers are not going to take you anywhere a bolt on coil lift wont in all but the most extreme situations that 99% of people will likely not encounter anyway. My feeling is that if you are going to start down the path of coilovers or struts and high horsepower engine and 60's + save you cash and put it into a purpose built rig. A predominantly production jeep is just not going to see the limits of the benefits some of these improvements may provide. You just end up chasing problems and by the time your done you kick yourself and say dam I should of just built a rig. Now all that said, if you got tons of cash that you don't give a shit about meaning your the type of guy who would take his car into the dealership for an oil change and instead of calling a cab home you just buy another car while your there to get home and pay cash for it, spend away. Again just my opinion others may vary.
Don't mean to hijack, but if you were just to get weld-on brackets and needed to build coilovers separate, how do you know what springs to go with them?
For example, I am looking at the fox 2.0 w/ remote resi and 12" travel. Where do I begin with the coils?
Thanks. The last pic it was still on the lift checking for clearances, but it does have a lil lean. I have a few more turns on the preload on that side to help with the gansta lean. Ill get some pics posted with how she sits.
I think there was a thread started on here somewhere with spring rates and valving. If not might be a good idea to start since coil over set ups are getting popular.
Check out these links for some great info. He gives you the calculator for initial rates and also how to re check and change.
Coilover Spring Rate Calculator (Dual Rate Spring Calculator)
Off-Road Coilover Springs | How to Fix Your Coilover Springs
