Cutting pinch seam
Old 08-20-2014, 05:09 PM
afalletta's Avatar
Anyone have the AEV 2.5" lift and 35" tires? Do I need to cut the pinch seam?
Old 08-20-2014, 05:30 PM
davegill's Avatar
Not sure if you have to bit I say why not?
It takes no time at all and a heavy layer of jb weld and I'm 5 years into my cut job..very simple mod with lots of gain
Old 08-20-2014, 05:33 PM
afalletta's Avatar
Originally Posted by davegill
Not sure if you have to bit I say why not? It takes no time at all and a heavy layer of jb weld and I'm 5 years into my cut job..very simple mod with lots of gain
As a DD for a while will it be ok?
Old 08-20-2014, 05:37 PM
Invest2m4's Avatar
Sure, until you hit a large bump and your tires give you a little help.
Why the resistance to cutting it? Literally takes 5 minutes to prep and cut. 20 to JB Weld cleanly. A little sanding after it dries and then some color match touch up paint and it will look like it came that way. They actually come from the factory with it cut now. And really, all they do is stamp cut it. Nothing fancy.
Old 08-20-2014, 05:39 PM
afalletta's Avatar
Originally Posted by Invest2m4
Sure, until you hit a large bump and your tires give you a little help. Why the resistance to cutting it? Literally takes 5 minutes to prep and cut. 20 to JB Weld cleanly. A little sanding after it dries and then some color match touch up paint and it will look like it came that way. They actually come from the factory with it cut now. And really, all they do is stamp cut it. Nothing fancy.
Ok no resistance but I'm driving from NJ to FL on Saturday and getting the tires on tomorrow so I'm crunched for time
Old 08-20-2014, 05:40 PM
afalletta's Avatar
It's just the rear right?
Old 08-20-2014, 06:45 PM
JustJeepinWithYa's Avatar
Have a 2.5 aev and 315 duratracs (more like a 34). Haven't cut mine and no problems here.
Old 08-20-2014, 07:02 PM
afalletta's Avatar
Ok thanks I'll see when I get the tires on haha
Old 08-20-2014, 08:17 PM
mhockey9090's Avatar
Yeah mine seem to be cut from factory.
Old 08-20-2014, 09:04 PM
DallasJKU's Avatar
I do and run 315's and didn't need to.
Quick Reply: Cutting pinch seam
