fender flare help !
Old Apr 2, 2009 | 04:42 AM
  #31
JPop's Avatar
Review what your state law says as I posted before. Make an appointment to see them with some sketches of what your proposed plans are before you actually come up with a solution as the law is pretty vague and I would believe in strict adherence to it a lot of new vehicles off the lot wouldn't comply.
I believe that as written, the further back any flaps or fenders are placed the higher from the ground they can be. Nothing written or implied has anything to do with the front fenders, so concentrate your efforts on the rear. Measure from the center of your axle to the rear front edge of your bumper, hang your solution there, make sure it comes within a third of the measured distance to the ground and covers the with of the tire tread. The stubby rear bumper is going to make it look a bit odd, but it should be removable if you tap the mounting points into the underside of the rear bumper.
Exhibiting good faith to try to correct the issue is going to go a lot further than trying to slide around things.
Old Apr 2, 2009 | 04:52 AM
  #32
racer83l's Avatar
wow that sucks.. here in NY we have some crappy laws.. but for passenger vehicles, our tires can stick out as far as we want them to. its the commerical guys that have this problem. Id move if I were you.
Old Apr 2, 2009 | 04:53 AM
  #33
MMO blk JK's Avatar
run for office then change the law
Old Apr 2, 2009 | 04:59 AM
  #34
greenamphibious's Avatar
here in florida we can roll with beadlocks and no fenders! Of course we have nothing but trails and mud but hey... our rigs are read in case they ever import mountains and rocks!
Old Apr 2, 2009 | 05:04 AM
  #35
STUPIDFACE's Avatar
Originally Posted by RedneckJeep
.........imagine yourself in someone else's shoes. That someone who gets a rock flung into their windshield at 75MPH as you drive by going the other way. So, that means 75MPHx2. Get the picture? We have two rock quarries close by. Dump trucks are sometimes flinging rocks off their tires and hitting other vehicles on the road. How would you feel if it happened to you? That's the kinda thing that can cause accidents.
Come on man. Let those among us with all of their tires under their fender flares cast the first stone....... uh, or not cast the first stone? well, you know.....
My tires do stick out past my flares, but when i come off of a rock road after runnin through a buncha mud, i try not to get on the highway until there are no cars in sight. I try to haul ass and sling all the rocks off as fast as i can. If some poor bastard catches a rock to the windsheild or whatever after that, well i guess shit happens. Its happened to me several times. I mean what else can you do? Have a jeep that dont look cool?
corey d
Old Apr 2, 2009 | 06:08 AM
  #36
JeepPilot88's Avatar
To the OP:
Do you have a picture from the side furthur back of your rig with the wide flares? I want to get some of those, look great!
Old Apr 2, 2009 | 06:28 AM
  #37
JK Rocker's Avatar
Not sure if its possible, but since you already have a set of narrow and wide flares, can you cut the edge off of one and use it as a spacer to make them both wider?
Just a thought. The contour of the flares probably wont match up, but maybe you could fabricate them together somehow...
Old Apr 2, 2009 | 06:34 AM
  #38
blockrockin's Avatar
i was just thinking about that... could work.. i think im going to try and use part of the stock flare that i trimed and attach it to the outside of the wide xenons enough to cover the complete tire.. i only need mayb 2 inches to cover them.. its very close.. ive seen most jeeps running around with a inch or two sticking out.. so ill see how it works thanks
Old Apr 2, 2009 | 06:40 AM
  #39
buy a cheap jeep for a DD and leave you JK as is
Old Apr 2, 2009 | 07:09 AM
  #40
STUPIDFACE's Avatar
Block,
Did the cop stop you just for the tire / fender issue?
corey d
