Gear install
Old Dec 11, 2007 | 08:36 AM
wayoflifette's Avatar
JK-Forum Founder
Not sure is this is what you need, but this is from the factory service manual:
3. Hold pinion flange (1) with Flange Wrench C-3281 (2) and remove the pinion nut.
4. Remove pinion flange (1) with Puller C-452 (2).
5. Drive pinion out of the housing with a dead blow hammer (1).
6. Remove pinion seal with seal puller.
7. Remove oil slinger (1).
8. Remove front bearing (1).
And here is a pic of the puller being used on our jeep when our gears were being installed:
ID:	4811   Click image for larger version
ID:	4812   Click image for larger version
ID:	4813   Click image for larger version
ID:	4814   Click image for larger version
Old Dec 11, 2007 | 10:05 AM
Capown's Avatar
ok that was pretty helpful but how do I get the first part of the flang off that connects to the driveshaft heres a pic..
I need to pull that sprocket off with the first flange.
2nd pic is called the prop shaft and the dealer ship won't tell me how to take it off. that part for ne1 that breaks it is 317bucks
ID:	4816   Click image for larger version
Name:	prop shaft.jpg
Old Dec 11, 2007 | 10:58 AM
Capown's Avatar
ttt new pics, talked to Donavee Jeep and there service tech would actually help me he said I need a special puller from Snap On
Old Dec 11, 2007 | 11:11 AM
john98026's Avatar
Angry Yes, I DO know what I am talking about
Originally Posted by Capown
Do you know what your talking about? Have you done this? They dont just sell or rent a pinion flange puller for our jeeps there is no U joint to pull out its just a shaft you have to pull from the inside from what my friend seen.
As a matter of fact, YES, I DO know what I am talking about! I have replaced the gears in my 2007 JK Unlimited.
OK. On a Dana 44, drain the oil (there is a nice drain plug just for that purporse. Now, pull off the rear cover. Mark the bearing caps to ensure that you put them on the way they came off and then take out the bolts holding the bearing caps. Make sure that you note which side the bearing races and shims came from. Use a couple of pry bars and carefully remove the differential. GBuy or rent an axle puller. It works fine for pulling the pinion flange from the Dana 44. After the flange is off, you can remove the pinion seal, pull out the bearing and beat the pinion out with a hammer.
From here on, you are on your own. The set-up is challenging and not something for the inexperienced. Get someone to help who actually knows how to set up the gears or you will be in a heap of trouble. Based on what you have written, I doubt that your friend is qualified.
Old Dec 11, 2007 | 11:20 AM
Capown's Avatar
He wanted to talk to you, to ask if your a douche. For doubting him. Speaking on his behalf he has probly done more gear swaps then u will do in ur life. What kind of axle puller are you using to remove the Prop shaft from the pinion yoke see pic 2 ^^ above in my 2nd to last post
Old Dec 11, 2007 | 11:52 AM
john98026's Avatar
Smile Just trying to help
OK. Let's call a truce, OK? No need for name calling. I used an axle puller that functions very much like the one wayoflifette showed in the pictures. Now let's be clear on what it is that you are trying to remove. Did you remove the 8 (I think there are 8) bolts that connect the drive line to the rear pinion flange? After taking the bolts out, I had to do some "persuading" with a dead blow hammer to get the driveline separated from the flange but I didn't need any special tools. If you have this off, then you should be faced with the pinion flange removal. By looking at your pictures, I am concerned that yours came apart where it wasn't supposed to.
BTW, I worked on a local Nascar for 3 years and would guess that I have performed 50+ gear swaps. Mostly Fords, granted, but I have done a lot of them. I really wish that our Jeeps had 3rd members. They are a LOT easier to work on
Last edited by john98026; Dec 11, 2007 at 12:14 PM. Reason: Spelling and added concern
Old Dec 11, 2007 | 12:24 PM
john98026's Avatar
Thumbs up Thanks!
Originally Posted by SDMF
You are not going to get very far acting like a dick to people.
Thanks! I am only trying to help.
Now, what are the chances that someone will design a kit to install 9" Ford diffs in our JKs? Think of the possibilities................
Old Dec 11, 2007 | 12:37 PM
Capown's Avatar
for one I wasnt being a dick to start he questioned or down played my friends ability when there was no reason for it. He did this for a living but in CC tx there are no people with JK's getting work done so hes never messed with something like this, everything else he had done in a hour.
Old Dec 11, 2007 | 12:50 PM
Capown's Avatar
Truce is ok with me, just dont appreciate you acting like my friend doesnt know what he's doing(neither did he thats why i put he wants to know if you were one). I removed the 8bolts from the Prop shaft where the driveshaft goes into the splines. There is a C clip that keeps the drive shaft it the Propshaft that came off maybe thats why there not coming off together and you see the inside splines where the shaft goes into the prop. I dont see how you used a axle puller to get that off the Pinion. thats where we are stuck. We cant get to the bolt to remove it and use a deadblow to knock it out.
Old Dec 11, 2007 | 12:57 PM
john98026's Avatar
Default I am done
Sorry but I tried to call a truce and you continue. I am done trying to help.
