Help! Jeep pulling left.
Old Jan 6, 2015 | 04:43 PM
Rebar-7's Avatar
Originally Posted by nautique210
I have the trail grapplers in 295 70 17 on this jeep. They measure out to around 33's. My last jeep I had them in 35's with no issues. Can you post the video link here. I'll do a search to see if I can find it. I'm running around 28 psi. I dropped the front left a tad to see if it would help till I found a solution. It hasn't helped.
Thanks.
My old I Pad won't let post that link, but I think if you google mounting tires on ATX Slab Bead locks
It should pop up. From Mel with off Road Evolution . It was on you tube I believe....
Old Jan 6, 2015 | 04:52 PM
mikeJKUR's Avatar
nautique210, have tried swapping the left front tire with right front to see if the pull moves to the right? A road force balancer will detech a tire pull so you could find a shop that has one to diagnosis the pull.
Old Jan 6, 2015 | 04:55 PM
mikeJKUR's Avatar
Croce and watson190, where are your alignment sheets?
Old Jan 6, 2015 | 04:58 PM
Croce's Avatar
I didnt get an alignment check, i just centered the steering wheel and corrected the toe-in.
Im gunna swap the front tires with one another and see if it follows the tire.
Old Jan 6, 2015 | 05:08 PM
watson190's Avatar
Hope this helps. I have no idea. The shop said everything looked good.
Old Jan 6, 2015 | 05:37 PM
Rebar-7's Avatar
Your castor looks pretty low, you have a 21/2" lift.....
Old Jan 6, 2015 | 05:46 PM
nautique210's Avatar
Originally Posted by Rebar-7
My old I Pad won't let post that link, but I think if you google mounting tires on ATX Slab Bead locks It should pop up. From Mel with off Road Evolution . It was on you tube I believe....
Good video. After watching it I have the flat squared edge out and the triangle edge in just like he does in the video. Guess that's not my problem but I appreciate the help.
Old Jan 6, 2015 | 05:50 PM
Yes I've tried rotating the wheels around. No luck. When I ordered the rim/tire combo it came mounted and balanced. Maybe wouldn't hurt to get them re done?
Rebar-7's Avatar
Well it was worth a try..
Old Jan 6, 2015 | 06:39 PM
watson190's Avatar
yeah, just the teraflex budget boost with shock extensions. Would low caster cause a pull to the left????
