Help! Jeep pulling left.
Old Jan 10, 2015 | 06:43 AM
  #31
mds22's Avatar
Originally Posted by nautique210
As I look around the web I'm seeing the tire being mounted two different ways. Some with the flat edge out and others with the triangle edge out. Heck even nittos web site has the triangle edge out. The video I watched from Mel at Evo had flat out. I'm going to email nitto to see what they say.
I think Mel said triangle out. Double check that.
Old Jan 10, 2015 | 07:02 AM
  #32
watson190's Avatar
Just thinking, if it is in fact a defect with the tread pattern and you mounted them 180* different, wouldn't the pull just go to the right instead of the left????
Old Jan 10, 2015 | 09:20 AM
  #33
nautique210's Avatar
When he gets done explaining the two different sides, it appears he says make sure you have the correct side out and points to the triangle side. But when the video goes on he mounts it with the flat out?? What's everyone think.
Even if triangle out is wrong I may try it. Just to see if it helps.
Old Jan 10, 2015 | 09:41 AM
  #34
mds22's Avatar
Interesting, let me watch that again....
Old Jan 10, 2015 | 09:48 AM
  #35
mds22's Avatar
He definitely mounted them triangle in / Square out. All mine were mounted triangle out. ??? Anyone know what's correct?
Old Jan 10, 2015 | 09:54 AM
  #36
mds22's Avatar
On their website nitto's pictures have them triangle out
Old Jan 10, 2015 | 10:19 AM
  #37
Dlampe's Avatar
I believe it is cosmetic. No right or wrong, just a personal preference. I would make sure they are all the same.
When you look at your Jeep from the front and you compare the tread pattern on the two tires, does the tread go diagonal from upper left to lower right on both tires? (I hope I explained that good enough)
Old Jan 10, 2015 | 02:59 PM
  #38
Originally Posted by Dlampe
I believe it is cosmetic. No right or wrong, just a personal preference. I would make sure they are all the same. When you look at your Jeep from the front and you compare the tread pattern on the two tires, does the tread go diagonal from upper left to lower right on both tires? (I hope I explained that good enough)
Yes
That's triangle in.
Old Jan 10, 2015 | 04:30 PM
  #39
Dlampe's Avatar
Not that I would do this but if you had triangle in on one side and triangle out on the other, would the "diagonals" run in opposing directions? I can't get my brain around that. If they did, I would think you would find a balance.
Old Jan 10, 2015 | 04:39 PM
  #40
Rebar-7's Avatar
Man I wish someone gets this pulling thing figured out. When I first mentioned the video
To nautique210 of Mel, ( off road evolution ) mounting these tires on ATX Bead locks. That's
The reason I watched the video, I have those wheels sitting in garage , I was going to mount
The Nitto's on for my next set of tires. But don't think Iam going to spend that kind of Coin on
a tire that has a constant nagging pull to it, No matter How cool they look. lol....
