Help! with pics :)
Old Apr 3, 2009 | 10:32 PM
  #101
mkjeep's Avatar
Originally Posted by Hellbound13
Take the bolt out and look in the sleeve. That where the marks on mine are..
I did , The marks of threads are almost un-noticeable, are yours obvious?
Old Apr 3, 2009 | 10:34 PM
  #102
Hellbound13's Avatar
No very faint as well. But the holes on the axle seem wallowed. if you put the bolt though the hole there is about 1MM of play.
Old Apr 3, 2009 | 10:36 PM
  #103
mkjeep's Avatar
Hold on letme go do that.
Old Apr 3, 2009 | 10:40 PM
  #104
mkjeep's Avatar
Ok, yes there is a minute amount of play, I'll ship it to you anyway if you want.Try some new bolts . Let met know Sunday.
Old Apr 3, 2009 | 10:41 PM
  #105
There is minute play where? I am talking about the holes on the axle mount not the trackbar itself. You wuold have to remove your trackbar and put the bolt in the hole to see. If yours is the same now I am wondering if the issue is something else. Tie rod?
Old Apr 3, 2009 | 10:42 PM
  #106
mkjeep's Avatar
Again, I had no probs at stock or with a 2in REBB with this trk bar torqued to 125 ft lbs. You may have just screwed up your bolts by over torqueing.
Old Apr 3, 2009 | 10:44 PM
  #107
Yeah that might be. I guess I will try new bolts and then go from there..
Old Apr 3, 2009 | 10:45 PM
  #108
mkjeep's Avatar
Ahh, I ain't changin trk bars this late as much as I like you, lol, the play I have is in the bushing. Does the hole look wallowed?
Old Apr 3, 2009 | 10:47 PM
  #109
Yeah the hole looks wallowed. There is about 1MM of space between the bolt and edge of the hole.
Old Apr 3, 2009 | 10:48 PM
  #110
mkjeep's Avatar
PM me Sunday, at least we'll eliminate the trk bar if you get mine.
