JK Pentastar Swap
not to hijack but why would you rather have the 3.8 w/ sc vs the 3.6 w/ sc seems you would have more power with the 3.6
I'm saying that by the time you drop in a 3.6 and then s/c, you're way into LS land in terms of price. Was just saying if I had a 3.8, I would s/c rather than get a 3.6.
duh! now i get it haha. i was hoping there was something i didn't know about my 3.8 that made it better then the 3.6 but just as i thought my 3.8 still sucks
That said, I am not sure a N/A LS is better than a blown 3.6. Look at the dyno chart for a twin screw on a 3.6 and then one for any N/A LS. I'm trying to spin 40s in the rocks in 4 lo. A blown 3.6 has way more torque at the bottom than an LS. Obviously, the ideal would be a blown LS, but that type of power gets hard to control when wheeling.
Sorry I have been slacking recently. I knew this would happen which is why I tried to get everything up before I forgot. Good intentions...
Anyhow, I am posting the price list so far including tax and shipping and improvements I didnt need (like a rubi transfer case, BR6 brakes, and new seats).
I still havent worked out every bug. Right now I have an EVAP error running the 2008 evap canister. So I have a 2013 canister, and the armor
to go with it, but I havent had a chance to see where the extra line is plumbed. The 2008 JK had two interfaces from the fuel cell to the EVAP, the 2013 has 3 interfaces, and the small one has a line that wanders off somewhere... That somewhere is what I need to find out. So anyhow, if any of you have removed your fuel tank and have pictures of the plumbing to the EVAP canister it would be much appreciated.
Also, as winter gets closer, I need to plumb the vacuum booster for the brakes. This hasnt been a problem yet, but I suspect cold weather may change that ..??
As for worth it.. yes. It was fun, I got to improve a ton of stuff, the 3.6 is noticeably more powerful and more efficient. I havent had any real issues yet, it runs smoothly, and I have logged quite a few long trips. I will say the 3.8 "felt" torquier off the line, but disappointed everywhere else. I was considering a stroked 3.8, but I am happy with what I ended up with. I would like to add an edelbrock, but that piggy bank needs more $.
Wiring diagrams still to come.
Prices below:
[TABLE="width: 932"]
[TR]
[TD]Part[/TD]
[TD]Price[/TD]
[TD]Source[/TD]
[/TR]
[TR]
[TD]Engine[/TD]
[TD]1500.00[/TD]
[TD]Ebay[/TD]
[/TR]
[TR]
[TD]Transmission[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Starter[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Clutch[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Radiator hoses[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]AC Comp (and one of the lines)[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Intake Manifold[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]2x PCM Wiring Harnesses[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Other Parts[/TD]
[TD]793.36[/TD]
[TD]From Engine Seller[/TD]
[/TR]
[TR]
[TD]Washer Resevoir and Mounting bracket[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Catalytic Converters[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]One Catalytic Converter bracket[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Mounting Thru Bolt x2 for New Motor Mounts[/TD]
[TD]-[/TD]
[TD]Old Engine[/TD]
[/TR]
[TR]
[TD]ABS Module[/TD]
[TD]-[/TD]
[TD]Saved from old washer mount[/TD]
[/TR]
[TR]
[TD]TIPM[/TD]
[TD]-[/TD]
[TD]Old Engine[/TD]
[/TR]
[TR]
[TD]Catalytic Converter Bolts (Header bolts from old engine): 6509967AA [/TD]
[TD]-[/TD]
[TD]Old Engine[/TD]
[/TR]
[TR]
[TD]Wiring Harness Connectors[/TD]
[TD]-[/TD]
[TD]Old Engine[/TD]
[/TR]
[TR]
[TD]Most of the mounting bolts[/TD]
[TD]-[/TD]
[TD]Old Engine[/TD]
[/TR]
[TR]
[TD]Exhaust Pipe Converter 68085142AB[/TD]
[TD]90.30[/TD]
[TD]Ebay[/TD]
[/TR]
[TR]
[TD]MOPAR MANIFOLD PIPE BRACKET 12+ JK 68110235AA[/TD]
[TD]26.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]MOPAR AIR TEMP SENSOR 12+ JK 5149182AB[/TD]
[TD]16.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]MOPAR FUEL VAPOR TUBE 12+ JK 68143715AB[/TD]
[TD]9.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]MOPAR FUEL VAPOR TUBE 12+ JK 68143716AB[/TD]
[TD]9.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]MOPAR HEX FLANGE HEAD BOLT M8X1.25X55 6105055AA[/TD]
[TD]11.96[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]MOPAR CATALYTIC CONVERTER BRACKET 12+JK 68051880AC[/TD]
[TD]19.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]MOPAR HEX HEAD SCREW/WASHER M10X1.5X50 6102172AA[/TD]
[TD]22.41[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]MOPAR EXHAUST MANIFOLD GASKET 12+ JK 68093232AA[/TD]
[TD]8.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]Y-Back Exhaust Pipe, Brackets, and Muffler[/TD]
[TD]150.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD]Complete Air Intake[/TD]
[TD]150.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD]3M Heat Shrink Butt Connectors with Adhesive: [/TD]
[TD]39.58[/TD]
[TD]Amazon[/TD]
[/TR]
[TR]
[TD]Transmission Jack Harbor Freight: 39178[/TD]
[TD]79.99[/TD]
[TD]Harbor Freight[/TD]
[/TR]
[TR]
[TD]Metric Double Box Ratchets: 68958[/TD]
[TD]22.99[/TD]
[/TR]
[TR]
[TD]SAE/Metric Thru Wrenched[/TD]
[TD]21.99[/TD]
[/TR]
[TR]
[TD]MOPAR FUEL VAPOR TUBE 12+ JK 68144603AB[/TD]
[TD]9.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]MOPAR STEERING PRESSURE HOSE 12+ JK 68078358AF[/TD]
[TD]84.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]BOLT. Mounting. Hex Flange Head. M10X1.50X60.0: 06104222AA x2[/TD]
[TD]2.89[/TD]
[TD]MoparPartsOverstock.com[/TD]
[/TR]
[TR]
[TD]BOLT AND WASHER, SCREW. Mounting. Hex Head. M12x1.75x50: 6501742[/TD]
[TD]5.35[/TD]
[/TR]
[TR]
[TD]LINE. A/C Suction And Liquid: 55111375AG[/TD]
[TD]135.66[/TD]
[/TR]
[TR]
[TD]HOSE AND TUBE. Heater Supply And Return: 55111396AC[/TD]
[TD]86.04[/TD]
[/TR]
[TR]
[TD]HOSE. Heater Core Jumper: 55111446AC[/TD]
[TD]26.01[/TD]
[/TR]
[TR]
[TD]Shipping for Moparoverstock[/TD]
[TD]48.95[/TD]
[TD]Morris 4x4 Center[/TD]
[/TR]
[TR]
[TD]MOPAR A/C Receiver Drier: 68003495AA-M[/TD]
[TD]94.97[/TD]
[/TR]
[TR]
[TD]MOPAR Receiver Drier O-Ring x4: 68026799AA-M[/TD]
[TD]15.96[/TD]
[/TR]
[TR]
[TD]MOPAR A/C 5/8" Slim Line Seal: 68100679AA-M[/TD]
[TD]4.97[/TD]
[/TR]
[TR]
[TD]MOPAR 1/2" Slim Line Seal: 68100680AA-M[/TD]
[TD]14.99[/TD]
[/TR]
[TR]
[TD]Crown Driver Motor Mount[/TD]
[TD]161.98[/TD]
[/TR]
[TR]
[TD]Crown Passenger Motor Mount[/TD]
[/TR]
[TR]
[TD]Air Hammer: 92037[/TD]
[TD]10.99[/TD]
[/TR]
[TR]
[TD]Tech Authority Account for 3 days[/TD]
[TD]35.00[/TD]
[TD]techauthority.com[/TD]
[/TR]
[TR]
[TD]30 Day subscription to www.eautorepair.net[/TD]
[TD]16.99[/TD]
[TD]eautorepair.net[/TD]
[/TR]
[TR]
[TD]PCM From 2013 Wrangler[/TD]
[TD]177.00[/TD]
[TD]billsusedparts.com[/TD]
[/TR]
[TR]
[TD]Reprogramming of PCM[/TD]
[TD]117.54[/TD]
[TD]controllertech.com[/TD]
[/TR]
[TR]
[TD]R-134A PAG 46 Refrigerant Oil[/TD]
[TD]6.30[/TD]
[TD]Advanced Auto[/TD]
[/TR]
[TR]
[TD]32oz Power Steering Fluid [/TD]
[TD]5.00[/TD]
[/TR]
[TR]
[TD]Antifreeze [/TD]
[TD]11.40[/TD]
[/TR]
[TR]
[TD]Exhaust Hanger Removal Pliers[/TD]
[TD]27.99[/TD]
[/TR]
[TR]
[TD]Engine Hoist[/TD]
[TD]169.99[/TD]
[/TR]
[TR]
[TD]Jeep Wrangler JK Brake Vacuum Pump: 04581586AA[/TD]
[TD]87.55[/TD]
[TD]unlimitedoffroadcenters on Ebay[/TD]
[/TR]
[TR]
[TD]Lower Radiator Hose: 55111395AE[/TD]
[TD]40.43[/TD]
[TD]Jeep Dealership[/TD]
[/TR]
[TR]
[TD]2 cans R134A[/TD]
[TD]25.98[/TD]
[/TR]
[TR]
[TD]r134a Can tap[/TD]
[TD]6.99[/TD]
[/TR]
[TR]
[TD]Fluid Lub Pump[/TD]
[TD]5.99[/TD]
[/TR]
[TR]
[TD]2 quarts ATF+4 fluid[/TD]
[TD]8.00[/TD]
[/TR]
[TR]
[TD]1 qt Valvoline DOT 3/4 Brake Fluid[/TD]
[TD]5.99[/TD]
[/TR]
[TR]
[TD]Tax on above[/TD]
[TD]3.42[/TD]
[/TR]
[TR]
[TD]Tech Authority Account for 3 days (again)[/TD]
[TD]35.00[/TD]
[/TR]
[TR]
[TD]Quick Connect and Fuel Vapor Pressure Sensor: 04593949aa[/TD]
[TD]27.99[/TD]
[TD]Ebay[/TD]
[/TR]
[TR]
[TD]Oil/Filter, and Air Filter, and Oil Wrench[/TD]
[TD]30.00[/TD]
[/TR]
[TR]
[TD]Vacuum Booster Hose: 68062139AC[/TD]
[TD]32.40[/TD]
[/TR]
[TR]
[TD]Fuel Pressure (natural Leak detector) Connector: 05143781AA, Vacuum wire connector 68148106AA[/TD]
[TD]63.16[/TD]
[TD]Drive Auto Parts on Yahoo[/TD]
[/TR]
[TR]
[TD]4 Quarts Royal Purple Synchromax[/TD]
[TD]63.56[/TD]
[TD]Pep Boys[/TD]
[/TR]
[TR]
[TD]EVAP Canister[/TD]
[TD]150.00[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]EVAP Skid (needed b/c 2008 canister has different mounts)[/TD]
[TD]80.00[/TD]
[TD]Amazon[/TD]
[/TR]
[TR]
[TD]SOLD: 2008 Catalytic Converter[/TD]
[TD]-50.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD]SOLD: 2008 Engine[/TD]
[TD]-350.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD]SOLD: 2008 Transmission[/TD]
[TD]-160.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD]SOLD: 2008 Transfer Case[/TD]
[TD]-80.00[/TD]
[TD]Craigslist
[/TD]
[/TR]
[TR]
[TD]SOLD: 2008 Passenger seat[/TD]
[TD]-100.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD]SOLD: Front Bumper[/TD]
[TD]-40.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Total[/TD]
[TD]4132.93[/TD]
[TD][/TD]
[/TR]
[/TABLE]
to go with it, but I havent had a chance to see where the extra line is plumbed. The 2008 JK had two interfaces from the fuel cell to the EVAP, the 2013 has 3 interfaces, and the small one has a line that wanders off somewhere... That somewhere is what I need to find out. So anyhow, if any of you have removed your fuel tank and have pictures of the plumbing to the EVAP canister it would be much appreciated. Also, as winter gets closer, I need to plumb the vacuum booster for the brakes. This hasnt been a problem yet, but I suspect cold weather may change that ..??
Prices below:
[TR]
[TD]Part[/TD]
[TD]Price[/TD]
[TD]Source[/TD]
[/TR]
[TR]
[TD]Engine[/TD]
[TD]1500.00[/TD]
[TD]Ebay[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Starter[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Clutch[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]793.36[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Old Engine[/TD]
[/TR]
[TR]
[TD]ABS Module[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]TIPM[/TD]
[TD]-[/TD]
[TD]Old Engine[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Old Engine[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Old Engine[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Old Engine[/TD]
[/TR]
[TR]
[TD]90.30[/TD]
[TD]Ebay[/TD]
[/TR]
[TR]
[TD]26.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]16.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]9.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]9.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]11.96[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]19.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]22.41[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]8.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]150.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD]150.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD]39.58[/TD]
[TD]Amazon[/TD]
[/TR]
[TR]
[TD]79.99[/TD]
[/TR]
[TR]
[TD]22.99[/TD]
[/TR]
[TR]
[TD]21.99[/TD]
[/TR]
[TR]
[TD]9.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]84.99[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]2.89[/TD]
[/TR]
[TR]
[TD]5.35[/TD]
[/TR]
[TR]
[TD]135.66[/TD]
[/TR]
[TR]
[TD]86.04[/TD]
[/TR]
[TR]
[TD]26.01[/TD]
[/TR]
[TR]
[TD]48.95[/TD]
[/TR]
[TR]
[TD]94.97[/TD]
[/TR]
[TR]
[TD]15.96[/TD]
[/TR]
[TR]
[TD]4.97[/TD]
[/TR]
[TR]
[TD]14.99[/TD]
[/TR]
[TR]
[TD]161.98[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]10.99[/TD]
[/TR]
[TR]
[TD]35.00[/TD]
[/TR]
[TR]
[TD]16.99[/TD]
[/TR]
[TR]
[TD]177.00[/TD]
[/TR]
[TR]
[TD]117.54[/TD]
[/TR]
[TR]
[TD]6.30[/TD]
[/TR]
[TR]
[TD]5.00[/TD]
[/TR]
[TR]
[TD]11.40[/TD]
[/TR]
[TR]
[TD]27.99[/TD]
[/TR]
[TR]
[TD]169.99[/TD]
[/TR]
[TR]
[TD]87.55[/TD]
[/TR]
[TR]
[TD]40.43[/TD]
[/TR]
[TR]
[TD]25.98[/TD]
[/TR]
[TR]
[TD]6.99[/TD]
[/TR]
[TR]
[TD]5.99[/TD]
[/TR]
[TR]
[TD]8.00[/TD]
[/TR]
[TR]
[TD]5.99[/TD]
[/TR]
[TR]
[TD]3.42[/TD]
[/TR]
[TR]
[TD]35.00[/TD]
[/TR]
[TR]
[TD]27.99[/TD]
[TD]Ebay[/TD]
[/TR]
[TR]
[TD]30.00[/TD]
[/TR]
[TR]
[TD]32.40[/TD]
[/TR]
[TR]
[TD]63.16[/TD]
[/TR]
[TR]
[TD]63.56[/TD]
[TD]Pep Boys[/TD]
[/TR]
[TR]
[TD]150.00[/TD]
[TD]Quadratec[/TD]
[/TR]
[TR]
[TD]80.00[/TD]
[TD]Amazon[/TD]
[/TR]
[TR]
[TD]-50.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD]-350.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD]-160.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD]-80.00[/TD]
[TD]Craigslist
[/TD]
[/TR]
[TR]
[TD]-100.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD]-40.00[/TD]
[TD]Craigslist[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Total[/TD]
[TD]4132.93[/TD]
[TD][/TD]
[/TR]
[/TABLE]
I think it would be useful to people if you also posted a cost number for just the swap.
As for the EVAP, there is the additional line coming from the tank (but you can connect to any of the small evap lines). At the end of that line is a sensor of some sort that is wired to the engine bay. No clue where it goes. I put a custom fuel cell in and just made sure it was all hooked back up and I have zero codes.
I updated the list in the previous post to justthe parts needed for the swap (including tools I didnt have like hoist and tranny jack, and some wrenches). Subtract tools and it is about $400-$500 cheaper.
For the small line coming from the fuel tank, I know where it hooks into the EVAP, but where does it hook into the fuel tank? Is it up front? Do you have a picture?
The sensor you refer to is the fuel pressure sensor. I had to wire one in ('08 did not have it, but '13 requires one or an emissions code gets tossed), and splice it into the fuel filler vent line: picture later.
