Looking to buy this jeepto get back into a wrangler. Want you're opinions
Old Apr 13, 2018 | 03:43 AM
WILLYSwildcat's Avatar
Default Looking to buy this jeepto get back into a wrangler. Want you're opinions
My wife and I were looking at jeeps and came across this one. Its built exactly the way she had envisioned. Dealer is letting me take it over night tonight. Wanting your opinions and what specifics I should be inspecting. It is a Rubicon with 4.10s.
Thanks for any input. Below is the link
https://www.raysautotx.com/mobile/vehicles/1c4hjwfg7cl130402-2012-jeep-wrangler-unlimited-used-suv-midland-tx.htm
Old Apr 13, 2018 | 05:46 AM
resharp001's Avatar
Loved
Community Favorite
The mods are all personal preference, so if they’re up your alley, it looks like a decent deal. That looks like a DV8 fastback hard top…..which isn’t cheap (however neither are the smitty’s or ghost tops), and nice Warn powerplant. If that’s a real TOTL hood, nice quality part as well, might take a close look to see if that is real or a knock off. No great pics of the suspension……you might snap a couple to try and figure out what you have. Snap pics of the control arms and steering components up front. All in all, it doesn’t seem like a bad price for the mileage and build if you like it. Typically I don’t like the idea of buying used and already built, but this might be an exception if it’s done right…..and it appears the previous owner has spent some money. The ONLY thing that would have been better is if it was a ’13…..so you’d have bit more comfortable seats.
Old Apr 13, 2018 | 06:05 AM
TheDirtman's Avatar
All it needs is some 22" white wheels. Jump on it.
Old Apr 13, 2018 | 06:22 AM
TOTL Innovations's Avatar
Former Vendor
Its a knock off
Old Apr 13, 2018 | 06:28 AM
resharp001's Avatar
Loved
Community Favorite
Originally Posted by TOTL Innovations
Its a knock off
those pics are so small and couldn't blow em up. What is the dead give away to tell the real vs. knockoff?
Old Apr 13, 2018 | 06:44 AM
Former Vendor
If only looking a pics, there are 2 dead giveaways to look for. The first is a much more pronounced ridge down the middle of the hood. On our design, the ridge in the middle is very subtle, on the knock offs it looks like a Rhodesian Ridge Back. The second giveaway which is probably much easier to spot is that the side vents on knock offs are separate plastic inserts which stick out quite a bit and have a clear edge around them indicating that they are inserts. Those are molded into our hood for a much sleeker look.
In person, the knock off will obviously be made of metal while ours is fiberglass and the knock off will not have any hydra channels located behind the cowl vents to direct water away from your engine.
Old Apr 13, 2018 | 06:46 AM
resharp001's Avatar
Loved
Community Favorite
If only looking a pics, there are 2 dead giveaways to look for. The first is a much more pronounced ridge down the middle of the hood. On our design, the ridge in the middle is very subtle, on the knock offs it looks like a Rhodesian Ridge Back. The second giveaway which is probably much easier to spot is that the side vents on knock offs are separate plastic inserts. Those are molded into our hood.
Thanks. Was guessing some of it was the side vents....but couldn't tell if those were inserts or someone just painted black as to pronounce them.
Old Apr 13, 2018 | 07:27 AM
sellnotsale's Avatar
*yournotyou’re
Old Apr 13, 2018 | 07:38 AM
resharp001's Avatar
Loved
Community Favorite
Originally Posted by sellnotsale
*yournotyou’re
This ain't FB, Twitter, Instagram, or any other social network that it's fun to play grammar police. Least you can do is learn to use spaces if you're gonna call someone out for a trivial typo.
your<space>not<space>you're
Old Apr 13, 2018 | 08:44 AM
BoraBora's Avatar
*yournotyou’re
I'm embarrassed for you. Next time use spaces if you want to be the forum jackass who *attempts* to correct grammar while contributing nothing to the OP.
OP: I would pass. Is the exterior bedlined? Run. Once you get it dirty, good luck ever getting all the dirt and crap out. There's a lot of 'mods' on that thing that raises red flags such as the angry bird grill, red painted sway bar, stock tie rod, and stock diff cover. It's almost like one shop pumps out a million of these same JK/JKU's with the exact same mods.
