Low-cost / Free mods that should be done?
Old May 24, 2012 | 06:45 AM
  #1171
Phottomatt's Avatar
Originally Posted by jkrubcon
What are the screws hitting then? Theres no way you're running out of thread!
I think without the back part of the top the panels sit lower allowing the screws to go deeper.
Old May 24, 2012 | 06:53 AM
  #1172
WSU 5.9er's Avatar
I think the screws are only necessary if you run the top off but want to put the freedom top panels back on. I trimmed my screws down a bit and they don't hit the top with the spacer not folded out.
Old May 24, 2012 | 06:58 AM
  #1173
Hook-Em's Avatar
I belive this is correct also. If you have the freedom panels on with the main hard top, the L-latch secures the back of the freedom panels down. I never use my screws with the main panel in place.
Old May 24, 2012 | 07:48 AM
  #1174
damianplur's Avatar
Originally Posted by TYDFAN
Does it create a notable sound diff.? What about the dash speakers?
-Nathan
Yeahhh! It sounds better. I haven't made the dash speakers yet.
Here's the link:
https://www.jk-forum.com/forums/jk-e...eakers-230816/
Old May 24, 2012 | 07:55 AM
  #1175
Swoop69's Avatar
Originally Posted by jkuforu
Wow I hope you always have the drill with you just in case you wanna take it off any time or don't over tighten. I guess I'm still kind of young because I don't got arthritis just by turning in the top bolts. I still rather do it by hand
Its called being more efficient, and no, i wont carry my drill around with me, but why would I? I am not carrying the freedom panels with me either. I know how to operate a cordless drill, Do you? I know when to stop so I dont over tighten the bolts. You might not have arthritis, but your english sucks.
Originally Posted by jeeps_187
lol, classic burn by a young buck...
classic burn? hmm. im new here, but that was pretty weak.
Old May 24, 2012 | 08:06 AM
  #1176
TYDFAN's Avatar
My drill also has torque settings..
-Nathan
Old May 24, 2012 | 02:23 PM
  #1177
Fyrefighter's Avatar
More painting. I swear once you start you just think of more stuff to do. Got rid of chrome trim in gauges with a flat black and the rest gecko!
ID:	321015   Click image for larger version
ID:	321016   Click image for larger version
ID:	321017   Click image for larger version
Old May 24, 2012 | 03:07 PM
  #1178
Bxjk's Avatar
Hey FyreFighter. How hard is it to take the gauge cluster off? I'm a little hesitant to do this. Any info is greatly appreciated
Old May 24, 2012 | 03:17 PM
  #1179
Easy take off cover below steering wheel first. Then below cluster on bottom corners should be 2 bolts. Take them off. In between my air vents I have the little tray. Pulled it out and was bolt behind also. On top of dash where you can store stuff. Lift up tray another bolt. Start prying from any corner. 4 bolts on gauges is another 4 bolts. Back of gauges is 3 wires unplug. And remover clear cover and enjoy. Hope it helps. Btw this is for 2012 jk. Shouldn't be to different for you
Old May 24, 2012 | 03:21 PM
  #1180
Bxjk's Avatar
Awesome. I'm gonna order some spray cans and get this done. How many coats of paint an did you use a clear coat. Also any scuffing or sanding?
Thanks
