Plug and Play Remote Starter $100 on ebay
Old Feb 6, 2014 | 08:10 AM
  #131
Kentgu3's Avatar
Originally Posted by Kentgu3
I'm doing everything it says to do, even watch the YouTube video on it and when I get to the part with the flashing blue light, it won't flash it just stays on. Any help?
Nevermind, it was that stupid yellow wire that had to be spliced. After I did that it works great now.
  #132
Kentgu3's Avatar
Thanks rayjj that's exactly what it was
Old Feb 6, 2014 | 10:03 AM
  #133
petenice15's Avatar
I'm still waiting for my kit to be delivered from amazon and they've been amazingly slow for some reason. Can someone post a picture of the spliced yellow wires if they get a chance. I'm sure it will make sense once I have the kit in my hands, but I just wanted to make sure I don't mess anything up once it comes.
Old Feb 6, 2014 | 10:44 AM
  #134
rayjj's Avatar
My dash is all back together. It would be really hard to mess it up. Look for the 20 pin connector, which is white, and the 2 pin connector (also white) with the yellow and purple wires and just splice those 2 yellow wires together. The 20 pin connector is not part of the T harness. None of the other wires in that harness get connected to anything. The only thing you may have to do, if you have a factory alarm, is to ground that one wire (purple w/white stripe) during the install, as has been posted before. That 20 pin harness looks like this
Easy peasy!
Old Feb 6, 2014 | 11:10 AM
  #135
Sand Scorpion's Avatar
Ordered mine.
Old Feb 6, 2014 | 11:53 AM
  #136
Jeep Jedi's Avatar
Ordered mine on Amazon, should be delivered tomorrow or Monday. Hopefully tomorrow!!
Also I am a newb here but really like it compared to some of the other forums I have checked out.
Old Feb 6, 2014 | 01:04 PM
  #137
Woodbutcher's Avatar
They sure are...ordered mine on the 3rd, it shipped the 5th, but I supposedly won't get it till the 13th.
Here's what car alarms sent me when I asked about the hook up, EVO-ALL & THAR-CHR5 (T-Harness) if you read through it, it shows the connections highlighted in yellow.
Also, at the end in step 7 (the shaded gray area) it points out grounding the wire for the factory alarm. The way it reads it seems as though you could do 1 of 3 things, use your unlock button, ground out the wire or use the flashlink.
Someone said that the unlock button had no effect.
Many thanks to the OP and whom ever found it on amazon.
Welcome to the forum
Old Feb 6, 2014 | 01:20 PM
  #138
rayjj's Avatar
Yes only the grouding of that wire works unless you have the flashlink, which you really have no need to buy if you get a pre-programmed one. Funny my manual didnt list anything about the wire groudning, only showed the other 2 options. Must be an older manual. At least the module had a sticker that had a 12/13 date so it must be current. With all the winter storms of late I could see that delaying delivery potentially. I know they ship from CA, and I am in NY, so took a little time for me. I know earlier today they only had 1 listed as being in stock. The other seller lists them in stock, but apparently they are the ones that dont program them.
Old Feb 7, 2014 | 03:24 PM
  #139
KevinMac's Avatar
Thanks to BK and ray for their trouble shooting on the install. Mine came in today and using the work you guys posted, I had it in and working in about 15 minutes.
Spliced the yellows and trimmed the hell out of the rest of the unused stuff. You can also see I left the purple/white long for grounding purposes. Thanks again!
Old Feb 7, 2014 | 05:16 PM
  #140
Brass Knuckles's Avatar
Nice work! The only thing I find a bit quirky is that whenever I use the remote starter to start the Jeep, it no longers turns the headlights on when I exit the Jeep and lock it as it used to do normally. But, if I don't use the remote starter, the Jeep functions normally upon exiting the vehicle and locking the doors (lights stay on for 30 seconds). But, that's no big deal to me.
I'm such a nerd that I sometimes wait for my wife to come home and then start the Jeep as she's walking by it in the driveway. What a moron, I am!
