Prorock 44
Old Jun 30, 2017 | 11:29 AM
  #41
ktoth87's Avatar
Originally Posted by larry0071
Very doubtful. But what do I know, I'm just a lowly ASNT NDE Level III weld inspector at a nuclear plant
I was glad you answered. Your answer is what I was hoping on, someone who does it for a living. I was curious if dynatrac had an opinion. Should've been more specific.
Old Aug 15, 2017 | 11:03 AM
  #42
ktoth87's Avatar
I'm reviving this thread. So I had fixed the leak awhile back which can be read through. I've driven it daily since doing about 2500 miles and have had zero issues constantly checking it. This weekend I went from Rhode Island into the mountains in New Hampshire and bam got a leak out the tubes. If you read back. I had no issues when first installed until I drove cross country. Why do I have issues when I change elevation. I have had to literally cool down before I wrote this. So I wouldn't use all kinds of choice language. Dynatrac you didn't chime in when the weld in the C end was addressed. And I've been given the run around. What is going on here? I just bought mopar seals today and will replace them soon. The cost of seals is adding up. That'll be the fourth set of seals. In under 6k miles. This isn't hardcore wheeling either.
Old Aug 15, 2017 | 04:35 PM
  #43
LidLess07X's Avatar
What does the shop that you handed $5k over to have to say about this ?
Old Aug 15, 2017 | 08:04 PM
  #44
ktoth87's Avatar
They are kind of in between and have been nothing but helpful. Last time I talked to them they said if the housing needed to be warrantied they would get the ball rolling. But I want to know if this is something that needs to be warrantied. Between the constant leaking and the weld. Honestly I'm so pissed off with this axle that I don't even want it and would rather go with a different 44.
Old Aug 15, 2017 | 08:44 PM
  #45
Ripa777's Avatar
Did dynatrac set up the axle ?? Or did u buy just the housing? I purchased the housing and had leaks.... luckily I live close to dynatrac so they agreed to look at my diff. They had my rig a few days and pulled entire frt diff apart and found that the install shop didn't set my gears and locker within their specs and this is causing a leak at the pinon seal. So it may or may not be dynatrac issue.
Old Aug 16, 2017 | 12:19 AM
  #46
ktoth87's Avatar
The papers that came on the pallet that was falling apart said northridge. It's the tube seals leaking
Old Aug 16, 2017 | 12:21 AM
  #47
ktoth87's Avatar
Basically why when I change elevation it leaks. While in New Hampshire it was leaking noticeably not just damp. Now back in Rhode Island it's fine.
Old Aug 16, 2017 | 04:54 AM
  #48
Dynatrac's Avatar
Sponsoring Manufacturer
This is a tough one for us to address. If we remember correctly, you did not purchase the axle directly from us. And it is equipped with axle shafts and other components from companies that we don't use or sell. It is hard to tell what could have happened to our housing after it left our facility and went through one or two dealers before going into your Jeep. You mentioned poor welding, which is not typical on Dynatrac axles. Is it possible someone worked on the axle prior to it being installed in your Jeep? We dont want to cast doubt on others involved in this build, but it is odd that we be held accountable when others have worked on the axle and your Jeep. The bottom line is that the shop you bought the axle from is the one who should be helping you resolve issues. And if they bought the axle from us, the shop should be working with us directly. That is part of why you use a local shop or retailer, right?
If we had assembled this axle, sold it to you and shipped it to you complete, we would stand behind it 100 percent. We hope you'll give us the chance in the future to experience the quality of a complete Dynatrac axle assembly and buying direct.
Old Aug 16, 2017 | 05:48 AM
  #49
jordy's Avatar
Loved
Community Favorite
I'm not sure why Dynatrac is taking the hits here. I'd be leaning on the shop that you bought it from and have them lean on whoever put it together. From what I've seen on here, Dynatrac has been nothing but helpful, but this really isn't their issue when it has somebody else's hands all over it.
Sorry about your situation, but I think you're focusing on the wrong party to get it resolved.
Old Aug 16, 2017 | 07:54 AM
  #50
ktoth87's Avatar
I'm not trying to point blame at anyone particular company. I'm just trying to figure out what's wrong with this and get some answers. The weld is no question a dynatrac issue, unless you sell an unlimited housing that's stamped without c ends. The weld Im questioning is the c end weld. I pulled it apart again today. I have a stack of three sets of seals all different makes. I was told by 2 different people at the dynatrac booth at ejs that I tore the seals. Apparently not. And why at higher elevation does it leak? But not at sea level where I live?
