Superchips Error - Car is dead -HELP
Old Dec 13, 2013 | 06:40 AM
  #31
2013Sport's Avatar
Superchips said they setup a different recovery file.
I will try this tonight. If it doesnt work I wont be able to contact them until Monday.
Old Dec 13, 2013 | 07:17 AM
  #32
7kings's Avatar
Originally Posted by aldaman
Good to know. Hopefully when you take it into the dealer there is no trace that you used the Superchips as they may use that as their "way out" as not to replace your PCM under warranty. Best of luck..
aldaman
They will absolutely use this as a reason to not cover it under warranty if they know you were flashing the PCM - my advice is to keep it to yourself. In addition, I wouldn't be surprised to see your entire warranty impacted, since the PCM controls everything. A bad PCM could definitely cause the engine to damage itself, and I'm sure your warranty will be black-marked in a heartbeat.
Good luck, man - this sucks.
Old Dec 13, 2013 | 01:43 PM
  #33
2013Sport's Avatar
I registered the tuner when I got it therefore it should qualify for the limited warranty and if I am reading it correctly it says that if the tuner directly causes any failure on the vehicle it is covered up to $5000 as long as the repair is made at a authorized superchips dealer.
Does anyone know anything about this?
Old Dec 13, 2013 | 02:27 PM
  #34
jadmt's Avatar
JK-Forum Ambassador
I would be on the phone pronto to Superchips. Be interesting to see how well they back up thier warranty.
Old Dec 13, 2013 | 03:39 PM
  #35
2013Sport's Avatar
They are still trying to fix it. If it doesn't work that will surely be my next question. It's about to be a week the car has been broke.
I am very skeptical that it will work. Like I said my buddy worked for Diablosport before opening his own shop and he said its fried.
Old Dec 13, 2013 | 07:01 PM
  #36
2013Sport's Avatar
We will find out Monday if this 5th try doesn't work
Old Dec 15, 2013 | 04:10 PM
  #37
2013Sport's Avatar
The update they provided they said would fix the issue did not resolve anything. I will be calling them again tomorrow
Old Dec 15, 2013 | 05:00 PM
  #38
Locko's Avatar
From: Hawai'i, Miami , FL, Alaska, Tennesse..S America
Since no one has a clue, I am going to keep this updated for people with future issues.
The car will start right after trying to upload the recovery tune but has a CEL, and will not start after 10 minutes or so.
The code E-00 means the database failed to complete update (which makes sense since it failed to update on the computer). Superchips looked at the log and saw it just keep looping through the same firmware update. They said that if a firewall or anti-virus is on, it can prevent it from updating and these need to be turned off. I am going to try to update again tonight.
Sometimes the tuners need perfect voltage, try connecting your battery to a tender if you have it or jumper cables and try to recover it
Old Dec 16, 2013 | 05:01 AM
  #39
2013Sport's Avatar
I may try this tonight.
I just talked to Superchips. They said they will pay up to $300 to have the vehicle towed to the dealer and reflashed. I am a little unsure how to play this when they start asking questions. Should I un-install the aftermarket radio? I never got the car flashed so technically I didnt void the warranty, and I am not asking them to fix it under warranty. hmm....
I paid for the extended drivetrain warranty to 70k miles too, if they were to void it and not refund the money for that I would be really pissed.
Old Dec 16, 2013 | 05:25 AM
  #40
karls's Avatar
The aftermarket radio wasn't a problem when I had my dealer flash the computer. There were just a couple simple updates in the system that the new software was fixing, but it was a flash nonetheless.
How you plat it out is dependent upon the dealer's attitude, but I would simply say that the jeep isn't acting correctly and you'd like to go on ahead and get the PCM and such flashed back to stock.
Sent from my DROID4 using Tapatalk
