Superchips Flashpaq for JK, Initial Impressions
Old Nov 23, 2009 | 11:11 PM
  #1061
spinlock's Avatar
Originally Posted by hotdogging
Bump for the question
Yes it will work in a VM. I have both Parallels and VMware Fusion. In this case I used a WinXP VM in Fusion just because I had it up and running.
Once I got past a registration glitch on the web interface, it worked as advertised.
The only other glitch was when I loaded a couple of optional packages once the update with the latest firmware was done to my Flashpaq. It never gave me a message that the upload was complete, so I tried 3 times.
As it turns it out the optional packages had been loaded, I just never got a notification.
I have connected successfully twice since I purchased it to see if there any revs of the firmware.
In general, I would say it works as well as any other USB device in a Windows VM.
I definitely recommend it.
Old Nov 24, 2009 | 03:11 AM
  #1062
JPop's Avatar
Got my box of goodies from Superchips last night and happy to have a sticker to put on my tool chest.
Many thanks to Superchips for their support of this site and a great product that keeps getting better.
Old Nov 24, 2009 | 04:58 AM
  #1063
Hoopa70's Avatar
Been using VMware fusion with my superchip for 6-7 months. No problems. It would be nice to have it Mac compatible, then I could get rid of my windows partition all together. The superchip is the only reason I ever go into the filthy windows side of my machine.
Old Nov 24, 2009 | 02:11 PM
  #1064
Chewbee's Avatar
Default New to Form
Just installed SC on my 09 x 6spd 4door. I did the update and the install went fine but was wondering do I have to imput the fact that I already have an Airaid CAI and a Magnaflow exhaust or will it pick up on this on its own? I did the Quick Tune 87 Octane and the performance was only slightly better than before the install.
Thanks for the help
TMC
Old Nov 24, 2009 | 05:31 PM
  #1065
JPop's Avatar
Nope, that's it and you're all good. The PCM with the Superchips tune is still going use the MAP sensor and will adjust your A/F mixture accordingly. It might take a bit for the PCM relearn to happen but most see an immediate improvement.
Old Nov 25, 2009 | 10:10 AM
  #1066
jmcginn0414's Avatar
Sponsoring Manufacturer
Superchips Representative
Glad you are receiving them guys. Have a safe and happy Thanksgiving. For those that have not yet received them yet they will be going out after the holiday. I believe everyone that sent a note w/ contact info by last Wed has received. I"ve got a guy in Canada whose may take a little longer to get there so if he is reading this... rest assured I have not forgot about you.
Take care,
Jim
Old Nov 25, 2009 | 10:21 AM
  #1067
tls001's Avatar
Got my goodies in yesterdays mail. Thanks Superchips, you guys are awesome, just like the flashpaq
Old Nov 28, 2009 | 12:44 PM
  #1068
AK4Dave's Avatar
Hey all....I have a question....especially for you JPop if you happen to be around.... Some of you may have seen my post "Cold and MPGs" in the JK Talk section.
I haven't updated or retuned the JK since early summer. I was wondering if I updated the Flashpaq and retuned it now that it's cold out, if you think it might help with the fuel economy? I guess what I'm saying is, does the Flashpaq take into account the outside temp when it tunes your vehicle? So would it make a difference if I retuned it when it was in subzero temps? Or does it not make any difference......meaning, a tune is made in just one way and it doesn't matter what the outside temperature is....???
Thanks....
Old Nov 28, 2009 | 02:18 PM
  #1069
FastCarGuy's Avatar
Does anyone know if SC plans to add the ability to override the factory setting for disengaging/reengaging the electronic swaybar to make it stay off till a higher speed? Mine re-engages at around 15-18 mph.
Old Nov 28, 2009 | 02:46 PM
  #1070
bwiencek's Avatar
Thanks....
Since they're not completely re-doing the EFI setup and just "tweaking" the factory tune here's what the factory does:
The temp compensation is built into the tune - it's using the AIT (Air Intake Temperature) sensor to determine the temperature of the incoming air and uses it along with a couple other sensors to make a calculation on air density (and volume - so it can add the appropriate amount of fuel).
SO - that said - IMHO the only reason to update the flashpaq is to obtain the latest tuning parameters they have and possibly the additional features (i.e. tpms)... I think it's kind of like updating your PC's BIOS - If it's performing well and you're happy and there are no release notes (or posts) which say they've made a significant change that you need I'd just run what you've got...
