Superchips Flashpaq for JK, Initial Impressions
Old Dec 29, 2009 | 12:27 PM
  #1121
spinlock's Avatar
You remove after programming your Jeep, but each Flashpaq can only tune 1 Jeep.
You have to set the programmed Jeep back to stock before you program another one.
There are a couple of functions like data collection and rasing idle RPM that require the device connected.
  #1122
pastorsteve's Avatar
Yes. You program your vehicle then disconnect your programmer. However you can only program one vehicle at a time with the programmers. One per vehicle.
Old Dec 29, 2009 | 12:31 PM
  #1123
JKsJK's Avatar
Originally Posted by IcyFridge
I am strongly considering superchips, but all this talk of pinging and stuff makes me wary. I do not plan on using anything higher than 87 octane. I will be moving up to 33s soon.
i had pinging on my initial install, but there was a clear problem with the install because i had other issues - no speedo or odometer readings. reinstalled and have not had a problem since. i've tried a variety of settings and have never had pinging return.
Old Dec 29, 2009 | 01:29 PM
  #1124
jeepmedic's Avatar
Originally Posted by JKsJK
for the most part. you need it in there for data collection and for the lockers, but if you are just tuning it, you set the tune and don't need it until you want to change or do an update.
1 tuner per jeep, so 3 jks will need 3 tuners if you want them tuned simultaneously.
Thats a bummer...but I still want one !!
Thanks for all the replies
Old Dec 30, 2009 | 01:28 PM
  #1125
bradj1964's Avatar
So you cant shut off that stupid tpms light unless the sensors are still on all five wheels on the jeep? my 4 tires have no sensors but the spare does,this isnt as easy as I thought it would be to program,I guess im the only d---b a-- that is having a hard time trying to figure this thing out, I guess I should of just bought the aev pro cal it looks simple compared to the flashpaq ,for someone like me!
Old Dec 30, 2009 | 01:52 PM
  #1126
colorado_rubie's Avatar
depending on your dealer and their willingness to work with you they can disable the tpms for you. Some dealers work better with modified jeeps then others.
Old Dec 30, 2009 | 02:34 PM
  #1127
bradj1964's Avatar
Originally Posted by tackindy
I had to download the "Off Road" and "Off Road Disable" packages before it would work. You know you have it if you go in to change the "Tire Pressure" seetings and you see "Toggle" which is where you toggle the TPMS on or off.
YES! FINALLY! WOOOOOOOO HOOOOOOOOOOOO!
Did you download the off road and off road disable off the superchips website?I downloaded their program today and I didnt see anything about a off road and off road disable program, mine doesnt have the toggle on my tpms screen either,(I know its me not knowing what im doing with this thing)thanks in advance
Old Dec 31, 2009 | 09:27 AM
  #1128
bradj1964's Avatar
Finally figured it out it was right in front of me,actually in the bottom left corner of the downloaded page,I think I need some better glasses!
Old Jan 2, 2010 | 01:12 PM
  #1129
rotdog's Avatar
Great Review.I was traveling up to Mammoth for the open of the ski season, sorely dissapointed at the performance of the engine. After reading your post, I went and purchased a flashpaq. Along with the flashpaq, I also did the cold air intake. Let me tell you, It was like driving a new vehicle. The trans shift points are different, the dynamics of the throttle position and engine response is far better than stock. Also, you have many options to adjust. the biggest surprise, was my MPG went up by 2.3mpg. I still think my spedo is off, in what direction did you change your tire size by a quarter of an inch? up or down?
Old Jan 2, 2010 | 01:27 PM
  #1130
JPop's Avatar
Just use a gps to calibrate your speedo, dialing up or down your tire size.
If your speedo is too fast, adjust the tire size down, Too slow, adjust tire size up.
Oh and welcome to jk-forum.com!
