Superchips Flashpaq for JK, Initial Impressions
Old May 25, 2009 | 06:53 PM
  #181
JK07's Avatar
oppps my Bad
Running 93 octane really gives a lot of noticable performance but engine pings. So I backed off to 91 Octane still great but not like 93 tune.
I have been adding octane booster with 97 octane fuel over here so will try again now after 4 tanks running on 91 octane settings.
Old May 25, 2009 | 06:59 PM
  #182
Doc_D's Avatar
Originally Posted by Zak
oppps my Bad
Watch out... A lot of octane booster is snake oil. They'll say stuff like "Raises octane 6 points!" That means it raises the octane rating 0.6.
And if you think about it logically that makes sense. If you have an 18 gallon fuel tank nearly full of 97 RON and add in a quart of straight toulene (121 octane RON) you'd end up with (97 * 17.5 + 121 * 0.5)/18 = 97.6 octane (tada 6 points).
Old May 25, 2009 | 08:19 PM
  #183
aldaman's Avatar
Has anyone ever ran the Hypertech before getting the SC flashpack? If so is the difference in power from the SC enough to ditch the Hypertech and purchase the SC...If there is a dramatic difference I will definately purchase one...Thanks...
Old May 25, 2009 | 11:03 PM
  #184
JK07's Avatar
I am LOST what are you talking about educate me a little easy on formulas
Old May 25, 2009 | 11:16 PM
  #185
DHunter19's Avatar
Originally Posted by viper02
I have a MBRP Catback exhaust ready to be installed, and am programmed to the 87 Octane Performance settig. Should I reset to stock BEFORE installing the catback, or just go as is?
Thx in advance...
I would. Anytime you make tuning changes you should reset the computer. Going back to stock and then downloading the performance program after your upgrade would accomplish this.
You want it to learn/adapt to the new conditions so it can react accordingly.
Old May 26, 2009 | 02:28 AM
  #186
viper02's Avatar
Thanks DHunter19!
Old May 26, 2009 | 02:43 AM
  #187
i've been tossing around which i want to get ....glad I found this thread you've all sold me on the superchips thanks
Old May 26, 2009 | 04:26 AM
  #188
Doc_D's Avatar
Toulene is one of the highest octane components of fuel and usually a component (if not the only component) of an octane booster. A lot of turbo guys (Evos, WRX, etc) will purchase straight toulene and add large amounts to truely raise their octane (like 1 gallon of toulene for every 10 gallons of premium). Toulene has an octane rating of 121 RON.
My formula is a simple averaging of octane ratings between the 17.5 gallons of 97 RON and the 0.5 gallons of the 121 octane toulene which is probably what your octane booster is.
So if we average it out (extra parenthesis added for clarity) ((17.5 gallons premium * 97 RON) + (0.5 gallons octane booster * 121 RON)) / 18 total gallons = 97.6 RON average octane rating.
The nomenclature these octane boosters use (i.e. raises octane X points) is deceiving. The points they speak of are tenths. So in this example they might claim it raises the octane 6 points even though your effective octane is only going from 97.0 to 97.6.
If you want to make a serious improvement to your octane rating, find a source for clean straight toulene and add it 1 gallon toulene to 10 gallons premium fuel. Then the math will look like this
((16.2 gallons premium * 97 octane) + (1.8 gallons toulene * 121 RON)) / 18 total gallons = 99.4 RON
This is awefully expensive though unless you're running a Supra, WRX, Evo or something else where getting an extra 3 octane points can result in the ability to run more boost and more ignition timing and make an additions 50 horsepower to the wheels.
In fact alot of the Evo and WRX guys are going to methanol injection systems which are much more cost effective octane boosters. They use their existing windsheild wiper fluid resevoir and windshield wiper fluid motor to inject winshield wiper fluid (i.e. methanol). It's controlled by a computer and only injected when necessary. It's very ingenious and cost effective.
Old May 26, 2009 | 06:34 AM
  #189
JPop's Avatar
Toluene is a very dangerous chemical that can be absorbed through the skin. It collects in fatty tissue and through the lungs. If you don't have a serious need for this stuff stay away. Also, if you do use it make sure you have the appropriate equipment for handling it, ie gloves, respirator and goggles.
Old May 26, 2009 | 06:38 AM
  #190
JPop's Avatar
Mashing the throttle a few times as people are prone to do after such upgrades will also force a re-learn of the PCM. Going completely to stock and then back is what is most likely to throw some CELs and DTCs until it gets straightened around, which again will take at minimum a tankful of gas.
