Superchips Flashpaq for JK, Initial Impressions
Old Mar 26, 2011 | 01:52 PM
  #1991
sclan's Avatar
Originally Posted by Sahara_Maverick
I have been thinking about getting one. Main reason is my Jeep is automatic and I feel that the set change gear does not match my drive style, or driving conditions here. I feel it's constantly changing gear and struggling mostly when I am between the 30 and 40mph range.
How's the gear change timing using SC? s Is it easy or cumbersome?
You may try disconnecting the battery for 10 mins to reset the shift points. Then drive it for 500 miles the way you normally would to "relearn" your shift points.
At least that is what I've read. There is discussion on resetting the shift points on here. Check it out to verify.
Old Apr 8, 2011 | 09:54 PM
  #1992
Croce's Avatar
Default 87 Octane and Tow setting.
Ok so i've searched through this thread as much as humanly possible without my eyes bleeding. Ive seen alot of people ask if you can run 87 octane on the Tow setting and the best anwser ive found is that you can, as long as you dont have pinging after 50 miles.
Can anyone verify that it is Ok to use 87 with the tow setting and not cause any damage?
Thanks and sorry to ask the same question thats been asked 100x's but i cant seem to find a definite anwser on this and want to make sure im not going to cause any damage
Old Apr 9, 2011 | 02:36 AM
  #1993
itsajeepthing91's Avatar
As you mentioned many get away with running 87 on the tow tune. But to me it's one of those things if you don't trust it don't do it run the 91.
Old Apr 9, 2011 | 03:42 PM
  #1994
warpipe's Avatar
I just installed mine with the 87 tune. got it @ jeepers den in orlando $300. i will road test it in the morning.
Old Apr 10, 2011 | 02:47 PM
  #1995
warpipe's Avatar
WOW! what a difference from stock. i cant wait to try the 93 tune
Old Apr 10, 2011 | 03:05 PM
  #1996
Croce's Avatar
So i've been running Tow tune with 87 for about 120 miles or so with no pinging and love it. Much better response from off the line, highway acceleration seems better and gas mileage has increased by almost by 2mpg (using jeeps avg mpg).. Just tried the 87 tune and it felt alot like stock to me so im back to running the tow tune. Def worth the $200 i paid for it on craigslist
Old Apr 10, 2011 | 03:47 PM
  #1997
rubi08unlimited's Avatar
I've been running mine at 87 and upped it to 91 today running 93 octane. seemed a little better, shifting isnt as snappy as the tow tune. Absolutely no pinging, running the latest update from superchips, may work back up to the 93 tune once I've got a few tanks of 93 through my system (I was getting a slight ping last fall, hoping the updates have corrected it).
Old Apr 10, 2011 | 04:51 PM
  #1998
Jknockers's Avatar
Your gonna love the 93 tune, I bought it, updated it, installed it setting to 93 tune with SuperChips shifting, and I think it really woke the thing up and the shifting is now a lot better. I run 91 or if I can find it 93 octane. I got ping on first tank full about for first 10 minutes but I had half 87 octane and 91 octane in tank, now several 91 octane tanks later still no ping. It's all good
Old Apr 11, 2011 | 04:09 PM
  #1999
Dark_Star's Avatar
Just got my flashpaq a few days ago want to install the 87 Performance tune and its not listed. all i have is the 91 and 93 performance tunes???? i did the update before the install... i have a 09 rubi unlimited. did they do away with this tune because of "pinging" issues or something?
Old Apr 11, 2011 | 04:12 PM
  #2000
SilverJK12's Avatar
Hmmm that's weird. Maybe someone will chime in to help. Did you look under the quick tune setup?
