TeraFlex Falcon Shocks and Nexus Steering Stabilizer
I went to Fox, haven't had an issue since. (In full disclosure, I've knicked the reservoir body enough to shove it upward, but it didn't cave in like my 9000xl) Rancho's are fine for what they are, and I'm glad they are a popular product. But anything past a mild fire road, those things are going to suffer. There is simply no reason to put a shock body in harm's way rather than using a sleeve or similar shaft protector. Funny thing about rocks, is that they never lose in a fistfight with components.
Like a previous poster stated, the less of my Jeep that can smash into the rocks, the better. Look at this picture. If those are your shocks down low like that, what makes more sense? Less shock to smash, or more?
TF has gotten much better with their customer service and answering the phones. It's interesting that they'd put that number out, it should be tucked away in the instructions somewhere. Maybe it's just me but I'd think the weight of the vehicle would be a little more crucial than the tire pressure if they're going to set a ride quality baseline.
They've differentiated 2dr and 4dr so why wouldn't they put in a weight category vs the recommended tire pressure? It seems a little odd to me but then again we rate shock length by "generic lift" instead of collapsed/ extended length as it should be.
The odd thing to me was their use of 25psi for tuning. I don't design shocks so maybe it makes sense? When I look at it, for DD highway use, I'm running 30-35psi. For off-road use, I'm airing down to 13-15psi. These seem to be pretty common PSI's ranges for those uses. I'm guessing 25psi is therefore a good sweet spot of compromise for tuning in relation to tire pressure. It's in the middle of the more common PSI ranges. I wouldn't get the best performance at 30-35psi, and I wouldn't get the best performance at below 15psi, but would likely get decent performance at both.
I would also think that at 25 psi the suspension and shocks are going to be doing more of the work controlling the Jeep's frame and body movements where if you were airing down even further, the tires are going to absorb more of the uncomfortable hits and bumps. Thinking about it that way, it makes sense to me that they would tune the Falcon shocks to optimally work with tires set at 25 psi.
@TeraFlex
I'm considering running the New Falcon shocks, I was wondering if these might work with the MetalCloak JK Outboard Front Lower Shock Mount Spacer Kit #7104 and the MetalCloak JK Wrangler Shock Relocation & Clearance Kit # 7025?
Here were are on a fire road out in Sand Hollow, no damage to the knob or the shock.
Weird....
See below in bold
Weird....
See below in bold
Attachment 666148
So, to rectify poor design, I spend time and money to install a custom mounting option to protect entry level shocks?
Wait a minute we didn't design the lower shock mount the last time I checked
Hence why many spin the shock body to protect the knob
Like a previous poster stated, the less of my Jeep that can smash into the rocks, the better. Look at this picture. If those are your shocks down low like that, what makes more sense? Less shock to smash, or more? So to the point, spend the few bucks and get that shock up and out of the way.
Hence why many spin the shock body to protect the knobLike a previous poster stated, the less of my Jeep that can smash into the rocks, the better. Look at this picture. If those are your shocks down low like that, what makes more sense? Less shock to smash, or more? So to the point, spend the few bucks and get that shock up and out of the way.
Greg- how far out does that post sit? I can go measure.
The fronts shouldn't be an issue, but rear could be an issue.
Dennis Woods explained, at the Winter 4x4 Jamboree in Hurricane, UT, that there is no restriction due to the remote reservoir hose and that allows the valving to happen more accurately.
I just wish they weren't so darn much money.
I'll work on getting some pics with the shock removed and measurements so you have a better idea if you can make them work.
