Teraflex Leveling Kit Questions
Old Jun 4, 2011 | 06:13 PM
  #181
Dylanjam77's Avatar
Originally Posted by SpoonJK
Omg it's that cheap! Thanks guys!
Being a Canadian, does Dave deal with the Canadian site also?
Got mine from Northridge and just love it. With my flat flares and the leveling kit I will be running Toyo 295/70R's (34.1 X 11.7) as soon as my bfg's wear down just a bit more. SOOOOON!!
Old Jun 4, 2011 | 07:32 PM
  #182
Merlin4979's Avatar
...you mean like this?
Old Jun 4, 2011 | 09:49 PM
  #183
mwilterink's Avatar
looks good with the flat flares! that might have to be my next mod..
Old Jun 5, 2011 | 05:14 PM
  #184
Dylanjam77's Avatar
Exactly, except with black wheels and a Sunburst Orange 4 door Jeep... LOL Your rig looks great Merlin.
Old Jun 28, 2011 | 04:15 AM
  #185
Kojack's Avatar
Northridge are hooking me up with this leveling kit. I am going to replace the shocks soon as well.
Old Jun 28, 2011 | 05:40 AM
  #186
fsr402's Avatar
If/when you get this make sure to look at the sway bar links. They had a bunch of them go out with out two steel bushings in each. I got one of those kits and I have now been waiting longer for the replacements then I did for the kit.
Old Jun 28, 2011 | 06:28 AM
  #187
eastcoasting32's Avatar
what spidertrax would work with teraflex leveling kit and stock rubi tires?
Old Jun 28, 2011 | 07:27 AM
  #188
Merlin4979's Avatar
You don't necessarily need spacers if you keep the stock tires. However, if you go bigger/wider tires eventually - there is only one type of Spidertrax that is set to work with a JK 5"x5" bolt pattern. It is 1.5" thick, and is just a spacer, not an "adapter."
Here's the link from Northridge:
http://www.northridge4x4.com/proddet...SPIDER-WHS-010
Hope that helps!
Old Jun 29, 2011 | 02:23 PM
  #189
snowbdr88's Avatar
Default Need advice!
I have this budget boost kit, but the front end's starting to sag a bit. I have just over 61K miles on my '08 Rubicon Unlimited - so I'm thinking I might need shocks and/or springs.
A little help, anyone?
The ride's a bit soft now, too - but not horrible or anything.
And if I upgrade shocks/springs would I keep the level lift (2"/1"), or just use the new springs/shocks?
In case you can't tell, I've never done much with suspension, before!
Old Jun 29, 2011 | 07:59 PM
  #190
Hope that helps!
Thanks for the help!!
