Alpha Expedition: Gobi Roof Rack.
Old May 14, 2010 | 11:06 AM
  #451
b5rider's Avatar
Originally Posted by b5rider
First thing you do when you get the rack is lay everything out like a surgeon's table. Then you read the instructions. The pictures and the wording that matches are NOT on the same page, so you have to follow carefully. That said, everything goes together beautifully. This is a high quality rack that is well engineered. They use lock nuts on all the fasteners and there are not many pieces that look alike and have you scratching your head. I put it together by myself in about 1.5 hours. The only help you will need is to place the large rack on the top. You also could use some help in placing the windshield surround, but I covered the hood with furniture pads as not to scratch it and was able to install it on my own. I would give it 2 out of five on the difficulty scale and only because of the weight. If you can turn a wrench, you can install it.
Oh, and absolutely no drilling!
Old May 14, 2010 | 08:06 PM
  #452
mountainsoul's Avatar
Thanks for the feedback mate. Sounds like its not too difficult.
Old May 15, 2010 | 09:05 AM
  #453
Cedo Nulli's Avatar
It's a pretty easy install, very well designed. Having help to lift the basket is a plus.
Old May 15, 2010 | 09:30 AM
  #454
b5rider's Avatar
I don't have enough posts to put an item on sale in these forums , and I don't know if I'm allowed in this thread, but I'm selling the Hi-Lift jack accessory mount for this rack. It is still in the sealed box. Please look it up on eBay if you want it. It retails for 179 and my reserve is well below that.
Old May 22, 2010 | 02:51 PM
  #455
ratcals's Avatar
Okay I'm about to bite the bullet on this rack but have a concern regarding an aftermarket license plate bracke I have. Is this going to work with the Gobi rack?
http://www.quadratec.com/products/12526_1011.htm
Here's some pictures with measurements.
Thanks in advance.
Old May 22, 2010 | 04:22 PM
  #456
b5rider's Avatar
Thanks in advance.
Hope this helps. I threw one in gratuitously so you know what it looks like
ID:	69107   Click image for larger version
ID:	69109   Click image for larger version
ID:	69110   Click image for larger version
ID:	69111   Click image for larger version
Old May 22, 2010 | 04:57 PM
  #457
ratcals's Avatar
Thanks a bunch for the pictures. I think I should be good. I just checked the height because I was conerned about the pivot point but my bracket actually sits lower than the OEM.
Thanks again.
Old May 22, 2010 | 09:05 PM
  #458
Does anyone on here have an Eezi-Awn RTT mounted to their Gobi rack? Does it attach ok?
Old May 22, 2010 | 09:30 PM
  #459
remark's Avatar
Thanks again.
The pivot may not be an issue, but look out for the support and sticker below the pivot.
Old May 23, 2010 | 11:40 AM
  #460
ratcals's Avatar
I think I should be good with that too. The top of my bracked is 6.5".
