View Poll Results: Interested in new headlights
Yes
944
94.40%
No
56
5.60%
Voters: 1000. You may not vote on this poll
New JK Headlights
Old Apr 4, 2010 | 11:15 AM
  #811
IMFletch's Avatar
Originally Posted by awndray
Has anybody else noticed that the new housing doesn't quite sit tightly? They rattle and move around.
My IPF headlights fit perfectly with no issues.
Old Apr 4, 2010 | 06:22 PM
  #812
Littlejon's Avatar
x2 I have not had any problems in the past few months with any rattling, or anything. They are still sitting tightly against the mounts, and have not had any condensation in them either.
Old Apr 4, 2010 | 06:25 PM
  #813
X-caiver's Avatar
Are you sure you got the mounting rings aligned / tightened correctly?
I've not had any problems either,.
Old Apr 4, 2010 | 06:28 PM
  #814
Piginajeep's Avatar
YUP. Just drove 5,000 miles to moab and back, and still tight
Old Apr 5, 2010 | 05:44 AM
  #815
awndray's Avatar
Yup. Both are perfectly aligned, but there's some play. I'm just going to slap some foam tape on the tabs to tighten it up. It'll be fine.
Old Apr 5, 2010 | 06:49 AM
  #816
Steve's 95YJ's Avatar
You're not alone awndray, I had the same problem with mine.
I actually re-installed them three times as they kept jiggling around inside the bucket no matter how tightly I put on the retaining ring. In the end, I ended up taping a small piece of plastic to the outside tab on each light and that kept them from moving around.
Old Apr 8, 2010 | 02:45 PM
  #817
fadeout's Avatar
Just put mine in!!! the difference is unreal!
Old May 31, 2010 | 06:58 AM
  #818
Da_Sherps's Avatar
[QUOTE=Dr.McNinja;1569576]
Originally Posted by paulp575
Think about what you need for fog lights, or that matter any forward facing lamp. You need something that will allow you to see farther. WHite is considered "pure light." It's 100 percent transmission. If you place any color over that same white bulb, you have now decreased the amount of light being transmitted.QUOTE]
Uh, no. See, the sun isn't white. It is yellow. Evolutionarily we have better yellow vision at night than white. Yellow does create more glare.
If yellow wasn't better, night racing cars wouldn't use it.
The sun is infact not yellow, the sun emits a lot of white light. But when you look at it there is a yellow haze around it due to a number of things. Predominently I would put this down to refraction in the atmosphere.
If you look at the sun when it is at its highest in the sky it should appear to be white. At dusk the sun appears yellow to orange due to refraction in the atmosphere.
Old Jun 1, 2010 | 12:50 AM
  #819
pseacraft's Avatar
My kit arrived a week ago but had to wait for my '09 JK to come back from the mod shop before I could do the swap. Was very excited, got the first stock lamp off and...wait a second...my harness is H4 and I have a "running" light also in my stock headlamp just under the main bulb. Strange me thinks but must be due to my JK being an overseas model...
Time to do some extra work me thinks. :P
Old Jun 1, 2010 | 06:04 AM
  #820
Littlejon's Avatar
The export (overseas) models came with a Hella reflector, and H4 bulb.
